Re: Mixing Pump Gas With 110 Race Fuel?
[Re: Jonnyj00]
#2088412
06/08/16 03:39 PM
06/08/16 03:39 PM
Posts: 11,719 Portage,michigan
B3422W5
Portage,michigan
I do it constantly. Usually throw 5 gallons of 110 into the stock gas tank with the rest 93 pump. 10.5 compression iron head small block.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Jonnyj00]
#2088419
06/08/16 03:46 PM
06/08/16 03:46 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
12:1 I would run the 110 straight.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Jonnyj00]
#2088441
06/08/16 04:17 PM
06/08/16 04:17 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Have you considered E-85? Might be worth looking into.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: Jonnyj00]
#2088449
06/08/16 04:29 PM
06/08/16 04:29 PM
B3422W5
Portage,michigan
Agree. At 12 to 1 with iron heads I would run straight 110 to be safe
[Re: B3422W5]
#2088452
06/08/16 04:39 PM
06/08/16 04:39 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
With those pistons and open chamber 906 heads, I'd run straight 110 in it.
[Re: an8sec70cuda]
#2088526
06/08/16 07:16 PM
06/08/16 07:16 PM
Posts: 161 SE Iowa
Jonnyj00
SE Iowa
Thanks for the input guys I was hoping to save a few bucks but if it's questionable at all I will continue to run straight 110. If I made the switch to aluminum heads someday would this be more favorable to a fuel mix? I have thought about E85 but I am just now getting to where I can tune a gas carb a little I don't want to change now very bad lol. Plus the switch to E85 can be a bit expensive initially... Thanks again!
[Re: Jonnyj00]
#2088540
06/08/16 07:31 PM
06/08/16 07:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks for the input guys I was hoping to save a few bucks but if it's questionable at all I will continue to run straight 110. If I made the switch to aluminum heads someday would this be more favorable to a fuel mix? I have thought about E85 but I am just now getting to where I can tune a gas carb a little I don't want to change now very bad lol. Plus the switch to E85 can be a bit expensive initially... Thanks again! Within a year you will save enough to make the switch to E-85... just have to understand that you only buy E-85 during the summer months so if you need to you fill a couple of 55 gal drums when it tests fine(the tester is cheap).. I use to ask the person ahead of me if I could get a small sample then test it... never had anyone say no.. and they would normally hang around to see the results
[Re: Jonnyj00]
#2088778
06/09/16 12:41 AM
06/09/16 12:41 AM
Posts: 472 Minnesota, USA
humpty
Minnesota, USA
We run 100 low lead aviation gas in our 12:1 iron W2 408. $4.50 a gallon and available pretty much everywhere. Its amazing how many small airports there are. We've made in excess of 725hp with it. Check out https://www.airnav.com/fuel/local.html, enter your zip code and you'll find all the local locations and prices.
[Re: humpty]
#2088806
06/09/16 01:09 AM
06/09/16 01:09 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
We run 100 low lead aviation gas in our 12:1 iron W2 408. $4.50 a gallon and available pretty much everywhere. Its amazing how many small airports there are. We've made in excess of 725hp with it. Check out https://www.airnav.com/fuel/local.html, enter your zip code and you'll find all the local locations and prices. I agree, exactly what I do down under.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: humpty]
#2088811
06/09/16 01:17 AM
06/09/16 01:17 AM
Thumperdart
State of confusion
Good luck letting em pump av gas in a can or in your car out west where I`m at..........epa lol..........
[Re: ozymaxwedge]
#2088813
06/09/16 01:18 AM
06/09/16 01:18 AM
RapidRobert
any pinging is as you know extremely damaging. as said max out your octane right off the bat then proportion downward till it talks on your hottest/driest (most likely to ping) day then back up a bit cuz there is silent ping & you want a cushion to protect your baby
[Re: Thumperdart]
#2088838
06/09/16 01:46 AM
06/09/16 01:46 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Good luck letting em pump av gas in a can or in your car out west where I`m at..........epa lol.......... LOL. you guys can't even buy a NORMAL gas can.
[Re: Jonnyj00]
#2088971
06/09/16 12:21 PM
06/09/16 12:21 PM
an8sec70cuda
Jonnyj00...100LL Avgas, if you can get, will work great in what you have and be a lot cheaper. My local airport lets me walk right in w/ my gas cans and get as much as I want. I think it's around $3 a gallon. I didn't even think about using Avgas when I first replied.
[Re: ozymaxwedge]
#2089010
06/09/16 12:49 PM
06/09/16 12:49 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
We run 100 low lead aviation gas in our 12:1 iron W2 408. $4.50 a gallon and available pretty much everywhere. Its amazing how many small airports there are. We've made in excess of 725hp with it. Check out https://www.airnav.com/fuel/local.html, enter your zip code and you'll find all the local locations and prices. I agree, exactly what I do down under. x3 I've worked my way from 40% down to 25% LL mixed with 87 pump on all my iron-head 340's and 750 Aprilia. 10% on everything else. Never a problem. Ever. I can sure remember when people used to argue against avgas on here. Yep, "your car is not an airplane" . Well, I don't know what's wrong with yours but mine sure grows wings when the Av hits the tank.
Mo' Farts
Moderated by "tbagger".
[Re: an8sec70cuda]
#2089015
06/09/16 12:53 PM
06/09/16 12:53 PM
MR_P_BODY
I've been asked to leave... because I was trying to buy av gas... some places dont play that at all.. I went in there with my buddy who is a pilot there... they said something to him also
[Re: MR_P_BODY]
#2089179
06/09/16 05:04 PM
06/09/16 05:04 PM
Posts: 179 Norfolk, NE
Racer33
Norfolk, NE
I walked into the airport Saturday morning and bought 5 gallons. Think I paid $3.79 a gallon. I put 40 miles on the Lycoming powered airboat Sunday so Friday before I go home from work I'll pick up 10 more gallons. They wont let me bring the boat to the pump but will watch me carry all the gas cans I want. lol My coronet will be running it instead of race fuel this year
