Re: Mixing Pump Gas With 110 Race Fuel?
[Re: Jonnyj00]
#2088412
06/08/16 03:39 PM
06/08/16 03:39 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
I do it constantly. Usually throw 5 gallons of 110 into the stock gas tank with the rest 93 pump. 10.5 compression iron head small block.
[Re: Jonnyj00]
#2088419
06/08/16 03:46 PM
06/08/16 03:46 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
12:1 I would run the 110 straight.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Jonnyj00]
#2088441
06/08/16 04:17 PM
06/08/16 04:17 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Have you considered E-85? Might be worth looking into.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: Jonnyj00]
#2088449
06/08/16 04:29 PM
06/08/16 04:29 PM
B3422W5
Portage,michigan
Agree. At 12 to 1 with iron heads I would run straight 110 to be safe
[Re: B3422W5]
#2088452
06/08/16 04:39 PM
06/08/16 04:39 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
With those pistons and open chamber 906 heads, I'd run straight 110 in it.
[Re: an8sec70cuda]
#2088526
06/08/16 07:16 PM
06/08/16 07:16 PM
Posts: 161 SE Iowa
Jonnyj00
SE Iowa
Thanks for the input guys I was hoping to save a few bucks but if it's questionable at all I will continue to run straight 110. If I made the switch to aluminum heads someday would this be more favorable to a fuel mix? I have thought about E85 but I am just now getting to where I can tune a gas carb a little I don't want to change now very bad lol. Plus the switch to E85 can be a bit expensive initially... Thanks again!
[Re: Jonnyj00]
#2088540
06/08/16 07:31 PM
06/08/16 07:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks for the input guys I was hoping to save a few bucks but if it's questionable at all I will continue to run straight 110. If I made the switch to aluminum heads someday would this be more favorable to a fuel mix? I have thought about E85 but I am just now getting to where I can tune a gas carb a little I don't want to change now very bad lol. Plus the switch to E85 can be a bit expensive initially... Thanks again! Within a year you will save enough to make the switch to E-85... just have to understand that you only buy E-85 during the summer months so if you need to you fill a couple of 55 gal drums when it tests fine(the tester is cheap).. I use to ask the person ahead of me if I could get a small sample then test it... never had anyone say no.. and they would normally hang around to see the results
[Re: Jonnyj00]
#2088778
06/09/16 12:41 AM
06/09/16 12:41 AM
Posts: 472 Minnesota, USA
humpty
Minnesota, USA
We run 100 low lead aviation gas in our 12:1 iron W2 408. $4.50 a gallon and available pretty much everywhere. Its amazing how many small airports there are. We've made in excess of 725hp with it. Check out https://www.airnav.com/fuel/local.html, enter your zip code and you'll find all the local locations and prices.
[Re: humpty]
#2088806
06/09/16 01:09 AM
06/09/16 01:09 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
We run 100 low lead aviation gas in our 12:1 iron W2 408. $4.50 a gallon and available pretty much everywhere. Its amazing how many small airports there are. We've made in excess of 725hp with it. Check out https://www.airnav.com/fuel/local.html, enter your zip code and you'll find all the local locations and prices. I agree, exactly what I do down under.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: humpty]
#2088811
06/09/16 01:17 AM
06/09/16 01:17 AM
Thumperdart
State of confusion
Good luck letting em pump av gas in a can or in your car out west where I`m at..........epa lol..........
[Re: ozymaxwedge]
#2088813
06/09/16 01:18 AM
06/09/16 01:18 AM
RapidRobert
any pinging is as you know extremely damaging. as said max out your octane right off the bat then proportion downward till it talks on your hottest/driest (most likely to ping) day then back up a bit cuz there is silent ping & you want a cushion to protect your baby
[Re: Thumperdart]
#2088838
06/09/16 01:46 AM
06/09/16 01:46 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Good luck letting em pump av gas in a can or in your car out west where I`m at..........epa lol.......... LOL. you guys can't even buy a NORMAL gas can.
[Re: Jonnyj00]
#2088971
06/09/16 12:21 PM
06/09/16 12:21 PM
an8sec70cuda
Jonnyj00...100LL Avgas, if you can get, will work great in what you have and be a lot cheaper. My local airport lets me walk right in w/ my gas cans and get as much as I want. I think it's around $3 a gallon. I didn't even think about using Avgas when I first replied.
[Re: ozymaxwedge]
#2089010
06/09/16 12:49 PM
06/09/16 12:49 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
We run 100 low lead aviation gas in our 12:1 iron W2 408. $4.50 a gallon and available pretty much everywhere. Its amazing how many small airports there are. We've made in excess of 725hp with it. Check out https://www.airnav.com/fuel/local.html, enter your zip code and you'll find all the local locations and prices. I agree, exactly what I do down under. x3 I've worked my way from 40% down to 25% LL mixed with 87 pump on all my iron-head 340's and 750 Aprilia. 10% on everything else. Never a problem. Ever. I can sure remember when people used to argue against avgas on here. Yep, "your car is not an airplane" . Well, I don't know what's wrong with yours but mine sure grows wings when the Av hits the tank.
Mo' Farts
Moderated by "tbagger".
[Re: an8sec70cuda]
#2089015
06/09/16 12:53 PM
06/09/16 12:53 PM
MR_P_BODY
I've been asked to leave... because I was trying to buy av gas... some places dont play that at all.. I went in there with my buddy who is a pilot there... they said something to him also
[Re: MR_P_BODY]
#2089179
06/09/16 05:04 PM
06/09/16 05:04 PM
Posts: 179 Norfolk, NE
Racer33
Norfolk, NE
I walked into the airport Saturday morning and bought 5 gallons. Think I paid $3.79 a gallon. I put 40 miles on the Lycoming powered airboat Sunday so Friday before I go home from work I'll pick up 10 more gallons. They wont let me bring the boat to the pump but will watch me carry all the gas cans I want. lol My coronet will be running it instead of race fuel this year
