Mixing Pump Gas With 110 Race Fuel? #2088401
06/08/16 03:31 PM
06/08/16 03:31 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
I have seen people mix pump gas with 110 race fuel in the past and get by with it but I wanted to get some of your opinions before I tried it with my combination.
My motor is a 12:1 383 with TRW dome pistons and stock 906 heads.
Could I get by with mixing 50/50 or 60/40 race fuel to pump gas without damaging the engine? I know that it would be easier with aluminum heads but I was just curious if it was possible with stock iron heads.
Thanks guys!!
Re: Mixing Pump Gas With 110 Race Fuel? [Re: Jonnyj00] #2088412
06/08/16 03:39 PM
06/08/16 03:39 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
I do it constantly. Usually throw 5 gallons of 110 into the stock gas tank with the rest 93 pump.
10.5 compression iron head small block.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Mixing Pump Gas With 110 Race Fuel? [Re: Jonnyj00] #2088419
06/08/16 03:46 PM
06/08/16 03:46 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
12:1 I would run the 110 straight.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Mixing Pump Gas With 110 Race Fuel? [Re: Jonnyj00] #2088441
06/08/16 04:17 PM
06/08/16 04:17 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Have you considered E-85? Might be worth looking into.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Mixing Pump Gas With 110 Race Fuel? [Re: Jonnyj00] #2088449
06/08/16 04:29 PM
06/08/16 04:29 PM
Portage,michigan
Portage,michigan
Agree. At 12 to 1 with iron heads I would run straight 110 to be safe
1.41 best 60 foot
6.56 at 104.17
Re: Mixing Pump Gas With 110 Race Fuel? [Re: B3422W5] #2088452
06/08/16 04:39 PM
06/08/16 04:39 PM
an8sec70cuda Offline
iagree With those pistons and open chamber 906 heads, I'd run straight 110 in it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mixing Pump Gas With 110 Race Fuel? [Re: an8sec70cuda] #2088526
06/08/16 07:16 PM
06/08/16 07:16 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Thanks for the input guys up I was hoping to save a few bucks but if it's questionable at all I will continue to run straight 110. If I made the switch to aluminum heads someday would this be more favorable to a fuel mix?
I have thought about E85 but I am just now getting to where I can tune a gas carb a little I don't want to change now very bad lol. Plus the switch to E85 can be a bit expensive initially...
Thanks again!
Re: Mixing Pump Gas With 110 Race Fuel? [Re: Jonnyj00] #2088528
06/08/16 07:18 PM
06/08/16 07:18 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
The worst part is a pump gas 400 with the right cam would probably run as fast as this 12:1 383... Oh well it's what I got.
Re: Mixing Pump Gas With 110 Race Fuel? [Re: Jonnyj00] #2088540
06/08/16 07:31 PM
06/08/16 07:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks again!
Within a year you will save enough to make the
switch to E-85... just have to understand that
you only buy E-85 during the summer months so if
you need to you fill a couple of 55 gal drums when
it tests fine(the tester is cheap).. I use to ask
the person ahead of me if I could get a small sample
then test it... never had anyone say no.. and they
would normally hang around to see the results
wave
Re: Mixing Pump Gas With 110 Race Fuel? [Re: Jonnyj00] #2088778
06/09/16 12:41 AM
06/09/16 12:41 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
We run 100 low lead aviation gas in our 12:1 iron W2 408. $4.50 a gallon and available pretty much everywhere. Its amazing how many small airports there are. We've made in excess of 725hp with it. Check out https://www.airnav.com/fuel/local.html, enter your zip code and you'll find all the local locations and prices.
Re: Mixing Pump Gas With 110 Race Fuel? [Re: humpty] #2088806
06/09/16 01:09 AM
06/09/16 01:09 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I agree, exactly what I do down under.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Mixing Pump Gas With 110 Race Fuel? [Re: humpty] #2088811
06/09/16 01:17 AM
06/09/16 01:17 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good luck letting em pump av gas in a can or in your car out west where I`m at..........epa lol.......... down
Re: Mixing Pump Gas With 110 Race Fuel? [Re: ozymaxwedge] #2088813
06/09/16 01:18 AM
06/09/16 01:18 AM
any pinging is as you know extremely damaging. as said max out your octane right off the bat then proportion downward till it talks on your hottest/driest (most likely to ping) day then back up a bit cuz there is silent ping & you want a cushion to protect your baby
Re: Mixing Pump Gas With 110 Race Fuel? [Re: Thumperdart] #2088835
06/09/16 01:42 AM
06/09/16 01:42 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yes you need to find a dodgy guy that has something to do with small planes and friend him smile
1971 Barracuda
Re: Mixing Pump Gas With 110 Race Fuel? [Re: Thumperdart] #2088838
06/09/16 01:46 AM
06/09/16 01:46 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
LOL. you guys can't even buy a NORMAL gas can.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mixing Pump Gas With 110 Race Fuel? [Re: Jonnyj00] #2088874
06/09/16 08:14 AM
06/09/16 08:14 AM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
I just take my 5 gallon cans to the airport near me and they fill them, pay the guy and leave.
Re: Mixing Pump Gas With 110 Race Fuel? [Re: Jonnyj00] #2088971
06/09/16 12:21 PM
06/09/16 12:21 PM
Jonnyj00...100LL Avgas, if you can get, will work great in what you have and be a lot cheaper. My local airport lets me walk right in w/ my gas cans and get as much as I want. I think it's around $3 a gallon.
I didn't even think about using Avgas when I first replied.
CHIP
Re: Mixing Pump Gas With 110 Race Fuel? [Re: ozymaxwedge] #2089010
06/09/16 12:49 PM
06/09/16 12:49 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
x3
I've worked my way from 40% down to 25% LL mixed with 87 pump on all my iron-head 340's and 750 Aprilia. 10% on everything else.
Never a problem. Ever.
I can sure remember when people used to argue against avgas on here. laugh2 Yep, "your car is not an airplane" blah .
Well, I don't know what's wrong with yours but mine sure grows wings when the Av hits the tank. devil
Mo' Farts
Moderated by "tbagger".
Re: Mixing Pump Gas With 110 Race Fuel? [Re: an8sec70cuda] #2089015
06/09/16 12:53 PM
06/09/16 12:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been asked to leave... because I was trying
to buy av gas... some places dont play that at all..
I went in there with my buddy who is a pilot there...
they said something to him also
wave
Re: Mixing Pump Gas With 110 Race Fuel? [Re: MR_P_BODY] #2089179
06/09/16 05:04 PM
06/09/16 05:04 PM
Norfolk, NE
Racer33 Offline
Racer33  Offline
Norfolk, NE
I walked into the airport Saturday morning and bought 5 gallons. Think I paid $3.79 a gallon. I put 40 miles on the Lycoming powered airboat Sunday so Friday before I go home from work I'll pick up 10 more gallons. They wont let me bring the boat to the pump but will watch me carry all the gas cans I want. lol My coronet will be running it instead of race fuel this year
