Re: What's a better engine, 5.7 or 6.4 hemi in a 3500 crew cab?
[Re: Whitey Nocar]
#2086085
06/04/16 10:44 PM
06/04/16 10:44 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Sorry, maybe I should have posted in question an answer section? Nope, in the truck forum. But here is fine. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif)
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Whitey Nocar]
#2086166
06/05/16 01:38 AM
06/05/16 01:38 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
6.4L. Steel crank, revised exh manifolds with extra bolts,coolant cooled egr,sodium filled inkenel exh valves and more. Med and Heavy duty versions. Way to go if there is no diesel option.
Leave the gun.......take the Cannoli's....Mike
[Re: Whitey Nocar]
#2086167
06/05/16 01:42 AM
06/05/16 01:42 AM
Posts: 43,638 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I bought a 2015 2500 4x4 with the 5.7 Hemi without MDS 383 HP and 400 TQ and really like it. It is a much different engine from the normal MDS 395 HP engine but hasn't been around long enough for long-term mileage testing, though I am sure it is pretty much the same as the regular 5.7 Hemi. I just turned 31K today coming back from Minnesnowta with nary a problem so far, I bought it in August last year. ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) I didn't but the 6.4 because of gas mileage concerns since I drive it daily, but also because it is only 410 HP and 429 torque, not that much different. ![work work](/ubbthreads/images/graemlins/custom/work.gif) My truck hauls my 32' LQ trailer loaded at 11K lbs with no issues. Gets about the same mileage as my 2004 diesel got towing, but not as good mileage not towing. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
JB Rhinehart, Realist
A-Body's RULE!
[Re: Whitey Nocar]
#2086204
06/05/16 05:51 AM
06/05/16 05:51 AM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
Well, you won't get 300k out of any of these new diesels without some expensive trinket failing on you. or $120 oil changes or higher cost for fuel at the pumps, plus DEF$. When you have 200k on a 6.4 or 5.7 you will be able to pick up another engine for $1500 at the autowrecker and keep on truckin'. 6.4 is the best in your spec. 5.7 would be great for a regular cab long-box.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2086978
06/06/16 12:41 PM
06/06/16 12:41 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Well, you won't get 300k out of any of these new diesels without some expensive trinket failing on you. or $120 oil changes or higher cost for fuel at the pumps, plus DEF$. When you have 200k on a 6.4 or 5.7 you will be able to pick up another engine for $1500 at the autowrecker and keep on truckin'. 6.4 is the best in your spec. 5.7 would be great for a regular cab long-box. Show me these 1500 dollar engines please! Especially a a non 5.7 hemi, or even a 5.7 without a 100k.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
