difference in cam ? #2086281
06/05/16 11:46 AM
06/05/16 11:46 AM
cedar rapids, iowa
superhog88 Offline OP
cedar rapids, iowa
is the only difference between a solid roller and a hydraulic roller the lifters if you had a solid roller could buy a set of hydraulic roller lifters and throw them in
Re: difference in cam ? [Re: superhog88] #2086307
06/05/16 12:14 PM
06/05/16 12:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Usually the ramp rate is mild on a hyd roller and
the solid roller tends to be quicker on the ramp..
but yes you can put a solid roller on a hyd roller
stick.. dont think I would go the other way
wave
