Page 57 of 81 1 2 55 56 57 58 59 80 81
Re: New Passon Performance 5 Speed update [Re: Slimfish] #2073070
05/14/16 02:20 AM
05/14/16 02:20 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Originally Posted By Slimfish
Old School, how are your's working? Are they staying in gear?
mine are doing great! one of them has fell out of 4th gear 3 times. I have about 400 miles on mine. it seemed to only do it when it was cold.
I think mine is a shifter adjustment. when in 4th, my shifter is a little more forward than the other one. when I adjust it, I will post back. I'm pretty sure that's what mine is.....
with some miles on them, they are very smooth and very quiet. cant wait for a couple more!
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2073090
05/14/16 03:55 AM
05/14/16 03:55 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Yikes. On my regular 23 spline 4 speed that came with my car it would jump out of gear when slowing down in that certain gear. Is that how it is for you all or is it when you're on the gas or just cruising or?
Dart sportsatellite does it happen in a certain gear or? Hopefully it's just fine tuning of the linkage and nothing inside the gearbox.
Re: New Passon Performance 5 Speed update [Re: 68KillerBee] #2073216
05/14/16 01:10 PM
05/14/16 01:10 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Your transmission is worn out....
Re: New Passon Performance 5 Speed update [Re: minivan] #2073513
05/14/16 09:21 PM
05/14/16 09:21 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Lol, I know. I rebuilt it after it started doing that. Now I replaced it with a hemi 4 speed. I was just asking the people that have these how/when it was popping out of gear.
Re: New Passon Performance 5 Speed update [Re: 68KillerBee] #2074099
05/15/16 09:03 PM
05/15/16 09:03 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Re: New Passon Performance 5 Speed update [Re: 68KillerBee] #2076122
05/18/16 09:46 PM
05/18/16 09:46 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The teeth that engage the slider to the gear are shot on the leeward side...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: New Passon Performance 5 Speed update [Re: 68KillerBee] #2078896
05/23/16 04:10 PM
05/23/16 04:10 PM
twin cities
dart_sportsatellite Offline
twin cities
Nope, not fine tuning, falls out of gear while cruising, and mine's not the only one, I'm the only one sharing the info though.
Re: New Passon Performance 5 Speed update [Re: dart_sportsatellite] #2078947
05/23/16 05:48 PM
05/23/16 05:48 PM
Alberta, Canada
572hemi Offline
572hemi  Offline
Alberta, Canada
Well I have almost 5000 miles on the transmission, I did have it pop out of 1st gear twice going down a grade, and a few times out of 5th. The 5th gear issue turned out to be a driveshaft issue, pinion angle was off a couple of degrees.
The car is heavy, 4100 lbs, 572 hemi, 735 HP, 717 T, 4:30 dana 60, 30" rear tires.
I think the transmission is great, just sayin
1967 GTX 572 HEMI 735 HP, 717 FT Lb T, , A-855 5 Speed, Dana 60 4:30 Gears, 30" Rear Tires
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2079251
05/24/16 10:53 AM
05/24/16 10:53 AM
Colorado
Slimfish Offline
Slimfish  Offline
Colorado
The production halt must be a result of the popping out of gear problem. Wonder if it has to do with parts quality again? Sure wish he could get a little luck going his way and get the issues behind and into full production to supply the waiting Mopar customers.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2081439
05/27/16 06:59 PM
05/27/16 06:59 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I would love one of these but deep in the back of my mind I feel if I do get one something will go wrong with it and it will end up as $5000 door stop.....I would feel much safer with the Passon 4 speed over drive and it can be purchased without any waiting period.
A new iron curtain drawn across the 49th parallel
Re: New Passon Performance 5 Speed update [Re: 572hemi] #2081683
05/28/16 04:27 AM
05/28/16 04:27 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Thanks 572Hemi for all the times you've posted on the performance of your 855. Even though you haven't posted much, please continue to do so. Hopefully every 1000 miles. smile
Your a rolling test bed and an extra gauge for me to watch.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2084197
06/01/16 05:51 PM
06/01/16 05:51 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I am afraid to drop 5K on a tranny that intermittently drops out of gear...I don't see how pinion angle can cause a gear to just pop out...the physics is not there in my feeble mind...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: New Passon Performance 5 Speed update [Re: astjp2] #2084221
06/01/16 06:45 PM
06/01/16 06:45 PM
Alberta, Canada
572hemi Offline
572hemi  Offline
Alberta, Canada
Wrong pinion angle causes driveshaft vibration, that will cause the trans to fall out of gear on a slight down grade where there is little pressure on the gears. My car is far from a stock deal, a lot higher springs on the rear than stock, hence the pinion angle problem. As I said before I have about 5000 miles on the 855 and it works great. Also I very much doubt you could ever get a better guy than Jamie to work with.
Just Sayin, and I had a new 67 GTX when I was 20 years old, so have been around the block a couple of times
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2084437
06/02/16 01:47 AM
06/02/16 01:47 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
But you can't be 100% that is the cause of poping out of gear...
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: New Passon Performance 5 Speed update [Re: toplescuda] #2084659
06/02/16 03:38 PM
06/02/16 03:38 PM
Alberta, Canada
572hemi Offline
572hemi  Offline
Alberta, Canada
Well it has not came out of 5th since the pinion angle correction, that was at least 3000 miles ago.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2096854
06/23/16 04:57 PM
06/23/16 04:57 PM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
Any updates guys more feedback?
Re: New Passon Performance 5 Speed update [Re: relax383] #2096952
06/23/16 08:25 PM
06/23/16 08:25 PM
Wyoming
64Barracuda Offline
64Barracuda  Offline
Wyoming
Ya, there has been no recent posts about receipt of A855s. Has anybody received a tranny in these last months?
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2108070
07/11/16 07:08 PM
07/11/16 07:08 PM
Wyoming
64Barracuda Offline
64Barracuda  Offline
Wyoming
Can someone swing by Jamie's booth at Carlisle and get us an update on the A855?
Re: New Passon Performance 5 Speed update [Re: 64Barracuda] #2108303
07/11/16 11:25 PM
07/11/16 11:25 PM
upstate western ny
sogtx Online work
sogtx  Online Work
upstate western ny
1st gear is for pansies.
1000 miles and mine is pretty smooth still.
Rolling burnouts . 1st gear launches on the redlines and sticky street tires .
I keep my hand on my shifter though, not on my ...
Im sure if theres a problem he will get down to a fix .
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2111095
07/16/16 12:24 PM
07/16/16 12:24 PM
The Dark Side
Fasbird Offline
Fasbird  Offline
The Dark Side
Emailed Passon about a month ago inquiring about list/order status. Never heard back from them. I got on the list three (3) years ago at the 2013 Nats. Jamie's dad was a real nice guy to talk to. Still hopin' my spot of 200 on the list isn't too far off.
