good,quiet elect fuel pump #2083521
05/31/16 05:24 PM
05/31/16 05:24 PM
ohio
ffej Offline OP
ffej  Offline OP
ohio
whats a good electric fuel pump for a street car? im looking for quiet unlike my holly blue pump and one that is made for continous use. thanks for any help!
Re: good,quiet elect fuel pump [Re: ffej] #2083532
05/31/16 05:43 PM
05/31/16 05:43 PM
I think there was mention of a carter street pump requiring no reg but I don't remember the #. Here's a BTT for ya
Re: good,quiet elect fuel pump [Re: RapidRobert] #2083565
05/31/16 06:50 PM
05/31/16 06:50 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
there is no such thing as a quiet electric pump but Robert is right. the Carter street pump is pretty quiet and doesn't require a regulator with Holley carbs. you can't beat the price either. i had one in for over 20 years and just replaced it last spring only cause i figured it was time. comes with the bracket, you supply the fuel fittings
Re: good,quiet elect fuel pump [Re: mikemee1331] #2083595
05/31/16 07:43 PM
05/31/16 07:43 PM
Michael we need the part number!
Re: good,quiet elect fuel pump [Re: RapidRobert] #2083605
05/31/16 08:02 PM
05/31/16 08:02 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Re: good,quiet elect fuel pump [Re: ffej] #2083618
05/31/16 08:28 PM
05/31/16 08:28 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
In the tank pump would be more quiet.
Re: good,quiet elect fuel pump [Re: ffej] #2083645
05/31/16 09:09 PM
05/31/16 09:09 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
John nailed it, the 4070. it was around the same price at Summit
Re: good,quiet elect fuel pump [Re: ffej] #2083648
05/31/16 09:14 PM
05/31/16 09:14 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I've had a Holley gerotor pump on my 470 Road Runner for years. It sounds like a typical in tank pump. I can hear it when I flip the key but not when the car is running.
Re: good,quiet elect fuel pump [Re: ffej] #2083755
05/31/16 11:01 PM
05/31/16 11:01 PM
NY
Beep Beep Offline
Beep Beep  Offline
NY
Yes that is the correct Carter fuel pump P4070, I was going to use that same pump.
Re: good,quiet elect fuel pump [Re: ffej] #2083945
06/01/16 09:35 AM
06/01/16 09:35 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How is your holley pump mounted? You didn't bolt it to a frame frail did you? Any inline electric pump should be mounted with two rubber P clamps on the body. Preferably with the body put into a foam or rubber sleeve before the P clamps go on.
Re: good,quiet elect fuel pump [Re: Sxrxrnr] #2083980
06/01/16 11:06 AM
06/01/16 11:06 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Not by much. My Warbro in tank pump is not much quieter than the Edelbrock external pump it replaced. Kind of an apples and oranges comparison though as the Edelbrock was a 7psi pump and Warbro is 50 psi plus.
Just thought it would be as quiet as my Ram 1500 or Durango pumps.
Craig
Re: good,quiet elect fuel pump [Re: ffej] #2084695
06/02/16 03:53 PM
06/02/16 03:53 PM
Indiana
Y
YO7_A66 Online content
YO7_A66  Online Content
Y
Indiana
""whats a good electric fuel pump for a street car? im looking for quiet unlike my holly blue pump""
My buddy and I both ran the Holley RED pumps and we both complained that they were loud at idle. I talked him into testing the Holley HP125 and he said that he could not hear it run at idle. So I bought the same pump and he was correct. No more buzzing noise at idle with the HP125 and I am using the same bracket setup that I used on the RED.
Re: good,quiet elect fuel pump [Re: YO7_A66] #2084710
06/02/16 04:25 PM
06/02/16 04:25 PM
ohio
ffej Offline OP
ffej  Offline OP
ohio
thanks for input!!
Re: good,quiet elect fuel pump [Re: ffej] #2084717
06/02/16 04:36 PM
06/02/16 04:36 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Don't know your budget...but a Fuel pump speed controller can quiet down a pump too. Especially one that is sorta quiet already...
http://www.aeromotiveinc.com/inside-aeromotives-fuel-pump-speed-controller/
