Advice on suspension - video is now attached #2083456
05/31/16 04:08 PM
05/31/16 04:08 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
Looking for some advice on my sons Dart, trying to get 60' down but getting very confused.
Last season we were running Calvert fronts And Rancho rears with Calvert mono's and Caltracs.. Over the winter we installed Viking Crusader "drag heavy" shocks, RMS front upper tubular control arms, qa1 dynamic strut bars. The car last year averaged a 1.43 60' foot and was pulling the front wheels off the ground 8-12 inches. The best 60' with the new setup has been about the same 1.43 - 1.44 but it is not pulling the front tires up "maybe a inch or so.. In this video the fronts are set at 2 for rebound, 4 on compression, rear 12 on extension, 2 on compression.. This thing should be 60' much better !!
Any advice is more than appreciated..
Thanks [video:youtube]https://youtu.be/J6JBO_ph2f0[/video]
Re: Advice on suspension - video attached [Re: 340KID] #2083464
05/31/16 04:25 PM
05/31/16 04:25 PM
Washington
madscientist Offline
Washington
I don't see a link to the video. Could be me.
Re: Advice on suspension - video attached [Re: madscientist] #2083472
05/31/16 04:39 PM
05/31/16 04:39 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
trying to upload it..
Re: Advice on suspension - video attached [Re: 340KID] #2083495
05/31/16 05:40 PM
05/31/16 05:40 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
I can't seem to upload the Video, keep getting a message its in the wrong format. its a mp4 video.. any suggestions ?
Re: Advice on suspension - video attached [Re: 340KID] #2083518
05/31/16 06:20 PM
05/31/16 06:20 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Put it on YouTube and link it here
Re: Advice on suspension - video attached [Re: FastmOp] #2083522
05/31/16 06:25 PM
05/31/16 06:25 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
just did, link is in my original post.. thanks
Re: Advice on suspension - video attached [Re: 340KID] #2083524
05/31/16 06:30 PM
05/31/16 06:30 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Looks like it didn't spin.
Re: Advice on suspension - video attached [Re: 340KID] #2083525
05/31/16 06:31 PM
05/31/16 06:31 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Hard to tell the video is kind of dark but I don't see any wheel spin.. time to turn up the horsepower
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Advice on suspension - video is now attached [Re: 340KID] #2083617
05/31/16 09:28 PM
05/31/16 09:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks like the back end isnt doing anything..no lift
to the body.. tells me you need to hit the tire harder
and what rpm is the launch
wave
Re: Advice on suspension - video is now attached [Re: 340KID] #2083678
05/31/16 10:39 PM
05/31/16 10:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It looks to me like it spins after the hit about the same time the front suspension tops out. Personally I would tighten the front rebound to slow the front rise and put a click or two in the rear compression.
Doug
Re: Advice on suspension - video is now attached [Re: MR_P_BODY] #2083833
06/01/16 02:07 AM
06/01/16 02:07 AM
CT
3
340KID Offline OP
340KID  Offline OP
CT
wave
I believe he was leaving around 2200-2400 rpm foot braking, I'm seeing the same thing, not much going on back there.. At the end of last season when we started racing it was reacting much better..and was leaving off idle..
Pic
Re: Advice on suspension - video is now attached [Re: 340KID] #2083964
06/01/16 11:37 AM
06/01/16 11:37 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
just curious.... what's the combo? mph in the traps? gear ratio?
Re: Advice on suspension - video is now attached [Re: J_BODY] #2083995
06/01/16 12:19 PM
06/01/16 12:19 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
it's a 493, with 727, 4.30 gear with 29.5x10.5w slick
per dyno sheets max torque 665 at 5100, max hp 710 at 6400rpm.may be a little more now due to some changes we made..
car is pretty consistent running 10.13-10.16 and going thru the traps at 131.5 - 132+mph.
Re: Advice on suspension - video is now attached [Re: 340KID] #2085574
06/03/16 10:35 PM
06/03/16 10:35 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Perhaps you should put last years shocks back in front and rear- get your base line back.
