Re: FINALLY got me a 360..
[Re: poboyengineering]
#2081689
05/28/16 04:47 AM
05/28/16 04:47 AM
Posts: 883 Affton MO
qwkmopardan
Affton MO
Quick Dan, what size valve did you use to get 280cfm out of the pass car heads? 2.055"
[Re: slantzilla]
#2081869
05/28/16 03:58 PM
05/28/16 03:58 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Are those heads the same as J heads? There all 'smogger' heads. What I noticed so far if that there is plenty of meat to get rid of the pushrod pinch completely. Always thought that was a T/A only deal. 587 production heads 4" bore @ 28" stock port w/ 1.88" valve Lift--------Intake cfm 0.150------91 0.200-----124 0.250-----157 0.300-----182 0.350-----199 0.400-----206 0.450-----212 0.500-----214 0.550-----211 0.600-----206 So right there you can get 400hp from bone stock heads This is from Chrysler Power magazine: 2.02 intake, hog out ports (pinch removed) blended guides, bowl Lift--------Intake cfm 0.150-----110 0.200-----149 0.250-----183 0.300-----210 0.350-----232 0.400-----250 0.450-----267 0.500-----281 0.550-----277 0.600-----270 potential 550-600hp heads W2 stock port .050------30 .100-----61 .200-----120 .300-----166 .400-----210 .500-----236 .600-----244 .700-----234 Stock 587 heads beat the stock W2 up to .350ish lift, after that game over. Ported 587 heads smokes the stock W2. But it's alot of work.. that could be applied to the W2 lol.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2081918
05/28/16 05:42 PM
05/28/16 05:42 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
What a head flows and what you get out of them for power are to totally different things!
Brian Hafliger
[Re: Brian Hafliger]
#2081942
05/28/16 06:47 PM
05/28/16 06:47 PM
DARTH V8Я
Its a TRAP!
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks.
[Re: DARTH V8Я]
#2081950
05/28/16 07:19 PM
05/28/16 07:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks. Did they have the rotators on them.. that makes them heavy ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2081952
05/28/16 07:24 PM
05/28/16 07:24 PM
DARTH V8Я
Its a TRAP!
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks. Did they have the rotators on them.. that makes them heavy Dunno. Whats it look like? That round thing under the retainer? ![](http://i1224.photobucket.com/albums/ee380/ASYLUM_thirteen/13322209_1037681126326852_6290527070103565574_n_zpswlt8rv9c.jpg)
[Re: DARTH V8Я]
#2081962
05/28/16 07:55 PM
05/28/16 07:55 PM
MR_P_BODY
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks. Did they have the rotators on them.. that makes them heavy Dunno. Whats it look like? But spring, keepers, retainer, valve weighed 239 grams. They are a bearing that allowed the valve to turn easier.. usually on heavy duty truck engines I dont have a pic of them.. but they were about a 1/4" to 5/16" thick... took the place of the retainer.. you would know if they were on there.. someone could have puled them off.. I always trashed them
[Re: DARTH V8Я]
#2081968
05/28/16 08:22 PM
05/28/16 08:22 PM
dartman366
Mt. Vernon, Ohio
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks. Did they have the rotators on them.. that makes them heavy Dunno. Whats it look like? That round thing under the retainer? the valve on the left side of the pic has the rotator usually on the exhaust valve from my experience.
[Re: MR_P_BODY]
#2082020
05/28/16 09:45 PM
05/28/16 09:45 PM
qwkmopardan
Affton MO
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks. Did they have the rotators on them.. that makes them heavy The spring on the left has a rotater. They were on exh valves on truck engines. If you were building a mild engine and wanted 340 springs you could not do it. The valves are made for a shorter spring. For what you are doing you will end up with .100 long sb chevy valves or maybe magnum valves. Don't try LS valves, I just did a set with LS valves, and what a PITA
[Re: DARTH V8Я]
#2082061
05/28/16 11:06 PM
05/28/16 11:06 PM
DARTH V8Я
Its a TRAP!
Yep. Parts. All in the guys apartment lol. 1974 360 .030 over ![](http://i1224.photobucket.com/albums/ee380/ASYLUM_thirteen/13256103_1037750886319876_3085334967003237563_n_zpsrvs2hhuc.jpg) 1973 360 Std bore ![](http://i1224.photobucket.com/albums/ee380/ASYLUM_thirteen/13237873_1037750946319870_2600893784657588416_n_zpsrbwqfval.jpg) 1976 360 Std bore ![](http://i1224.photobucket.com/albums/ee380/ASYLUM_thirteen/13265868_1037750909653207_6968882052906812596_n_zpseiiafesq.jpg) Game plan is the same. Cept going with W2's.
