Page 1 of 3 1 2 3
REV-N-NATOR #2079514
05/24/16 07:40 PM
05/24/16 07:40 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Has anyone had any feedback or experience with the REV-N-NATOR by
RT Garage http://thertgarage.com/images/header_Rev.jpg
http://thertgarage.com/images/MoparMaxOct2013/MoparMax_merged.pdf
Thanks Bob
Re: REV-N-NATOR [Re: tweeter1] #2079519
05/24/16 07:55 PM
05/24/16 07:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Quick google search here comes up with all of this rev-=n-nator
Re: REV-N-NATOR [Re: stumpy] #2079575
05/24/16 10:13 PM
05/24/16 10:13 PM
Stump that oughta keep him occupied for awhile!
Re: REV-N-NATOR [Re: tweeter1] #2079618
05/24/16 11:05 PM
05/24/16 11:05 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
They don't do anything special that you can't achieve with an MSD for much less money. They always compare these things to old-as-dirt Mopar controllers vs actual modern competitors.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: REV-N-NATOR [Re: Secret Chimp] #2079634
05/24/16 11:32 PM
05/24/16 11:32 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Thanks for the input it helps and is apprecited
Re: REV-N-NATOR [Re: tweeter1] #2080052
05/25/16 02:57 PM
05/25/16 02:57 PM
Tacoma, Washington USA
Adam71Charger Offline
A lot of guys tell me MSD's current boxes are way overpriced, how much is the revenator??
Re: REV-N-NATOR [Re: tweeter1] #2080079
05/25/16 03:20 PM
05/25/16 03:20 PM
Eugene, Oregon
Eugene, Oregon
You can get a Street Fire with a built-in rev limiter for $160 nowadays. It has slightly less spark energy than a 6AL but that is really not going to matter for most motors. The Rev-N-Nator alone is $210.
Re: REV-N-NATOR [Re: Secret Chimp] #2080131
05/25/16 04:49 PM
05/25/16 04:49 PM
My 2 cents: use a regular Mopar electronic dist/dial in the subsystems in order, initial/total/springs/vac can/get an HEI module/E coil/NGK or bosch plugs.
Re: REV-N-NATOR [Re: tweeter1] #2080135
05/25/16 04:54 PM
05/25/16 04:54 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I know a few guys with the REV-N-NATOR and they are happy with it. It is a plug in replacement for the stock Mopar ECU, so they did not have to wire anything and it adds a rev-limiter and maybe some performance?. I'm sure it is better quality than the Mopar boxes, but $200+ is a bit pricy.
Re: REV-N-NATOR [Re: RapidRobert] #2080140
05/25/16 04:57 PM
05/25/16 04:57 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
I gutted a stock black ECU & mounted a MSD-83647 HEI module w/ rev limiter in it. Was like $100 iirc, works awesome. Also went with the blaster II coil & NGK plugs. No problems.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: REV-N-NATOR [Re: DARTH V8Я] #2080188
05/25/16 06:52 PM
05/25/16 06:52 PM
cant beat that
Re: REV-N-NATOR [Re: tweeter1] #2080282
05/25/16 09:56 PM
05/25/16 09:56 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Don't ever use bosche plugs in anything, I have seen tons of bad ones out of the box, last week I fixed two dakotas with misfires after someone did a tune up, a 4.7 and a 5.2 both had new bosche plugs, regular and plat+4. A quick swap to NGK fixes em for good.
Re: REV-N-NATOR [Re: DARTH V8Я] #2080297
05/25/16 10:17 PM
05/25/16 10:17 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
How about a little more detail on this? The instructions call for installing the 83647 in a GM style HEI distributor. How do you use a Mopar style stock distributor?
My Revenator is on it's way to R/T now due to a hi speed miss. So I am exploring my options.
Thanks for any additional info!
Master, again and still
Re: REV-N-NATOR [Re: DaveRS23] #2080315
05/25/16 10:48 PM
05/25/16 10:48 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Google how to install GM HEI on Mopar.. tons of info.
there's this too: http://designed2drive.com/
Re: REV-N-NATOR [Re: DaveRS23] #2080348
05/25/16 11:20 PM
05/25/16 11:20 PM
How about a little more detail on this? How do you use a Mopar style stock distributor?
'75 & up HEI OE chebby black module (4 terminals). Or aftermarket one such as speedway motor dynamod but junkyard ones are cheap/reliable. the designed to drive piece to mount it looks nice but is very pricey, just cut a piece of 3/8 aluminum plate & shape it on your bench grinder (takes only minutes) & drill 2 holes to fit the two holes already in the bottom of the dist. Use some Radio Shack heat sink paste between HEI and plate. 12V to B terminal. coil neg to C terminal. W and G to dist pickup (I forget which is which on that but its in the archives). time it. EDIT to clarify, that 12V is to the coil positive primary
Re: REV-N-NATOR [Re: tweeter1] #2080437
05/26/16 12:57 AM
05/26/16 12:57 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Okay, I get it. I am shocked that this is the first I have heard of this conversion. I really like the idea of hiding the module in an old Mopar ECU housing and that the MSD unit has a rev-limiter.
For those of you that don't run a ballast with the GM style module, do you just tie the start and run circuits together?
Re: REV-N-NATOR [Re: DaveRS23] #2080441
05/26/16 01:03 AM
05/26/16 01:03 AM
Yes it dont get much press for some reason (& it is a chebby piece so it needs to be hidden). last one I did with an accell super coil, the big yellow beast with no ballast & it was a killer setup. you are supposed to run a ballast but you have ALOT of leeway on what you can and cannot get by with. yes tie the brown/blue together
Re: REV-N-NATOR [Re: RapidRobert] #2080448
05/26/16 01:21 AM
05/26/16 01:21 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Re: REV-N-NATOR [Re: DaveRS23] #2081093
05/27/16 02:09 AM
05/27/16 02:09 AM
dogdays Offline
dogdays  Offline
The 4 pin GM HEI is designed to use 12 volts. No ballast resistor is required.
You could look it up.
One of the reasons that the GM HEI worked so well was that they used an E-core coil. The kind with the laminations on the outside. This let more of the energy get to the plugs.
I have posted about the E-core coil before. Price for a good one on Ebay is holding firm at about $12.00.
R.
Re: REV-N-NATOR [Re: tweeter1] #2081095
05/27/16 02:16 AM
05/27/16 02:16 AM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
For the ballast I cut out the coils and solder in solid copper wire. Keepin it stealthy.
Page 1 of 3 1 2 3
