Gen 3 Hemi Critical Dimensions/Design Library Thread #2077080
05/20/16 12:52 PM
05/20/16 12:52 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Good Morning Guys, I spent some time with a local machine shop getting a 6.1 hemi cylinder head probed with the CMM(Component Measuring Machine) to get some critical measurements for my own needs. Once I clean up the dxf file data and create surfaces and points I'll post the dimensions that were found so that anyone who may need to used them, can.
Also, I figured this would be a good place to post critical dimensions as well so that anyone who may need them can easily find them. Below are some example dimensions that can be posted here for easy access.
OEM Installed Spring Height
OEM Valve Length
OEM Lifter Angle
OEM Light seat height
OEM Intake Valve Angles
OEM Exhaust Valve Angles
OEM Head Bolt Pattern Dimensions
OEM Valve Cover Rail Height
OEM Spark Plug Rail Height
OEM Valve Cover Rail Dimensions
OEM Camshaft Height (Camshaft Centerline to Crankshaft Centerline)
etc, etc
Anyway, you guys get the point. I think a quick library for this would be useful for anyone looking to build or design something for a gen 3.
Adriel Paradise
Substation Design Engineer III
Re: Gen 3 Hemi Critical Dimensions/Design Library Thread [Re: Adrielp] #2079913
05/25/16 11:29 AM
05/25/16 11:29 AM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Got my first few measurements from the data that are pretty common I believe but just case some people don't, here is the data that was taken from my 6.1 hemi cylinder heads.
Height from Cylinder Head Mating Surface(comb chanmber side) to Valve Cover Rail Surface: 4.625in
Height from Cylinder Head Mating Surface to top of Cylinder head bolt mating surface: 2.75in
Height from Cylinder Head Mating Surface to top of Spark Plug mating surface: 6.202in
Lower 8 Cylinder Head Bolt pattern dimensions:
4.453in Height by 4.46355in Width, with each cylinder bore as the center of this rectangular pattern. I will submit a drawing later so this is more clear.
Still deciphering the remaining data points. Should have dimension of spark plug centers in reference to the bolt hole locations. Will have the valve cover bolt hole locations, the rocker arm bolt pattern, the rocker arm shaft centers, and some valve location measurements.
Adriel Paradise
Re: Gen 3 Hemi Critical Dimensions/Design Library Thread [Re: Adrielp] #2082674
05/30/16 06:37 AM
05/30/16 06:37 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Can't remember where I found this
Alan Jones
Re: Gen 3 Hemi Critical Dimensions/Design Library Thread [Re: Adrielp] #2083508
05/31/16 05:56 PM
05/31/16 05:56 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Well shoot, if this was up earlier I could've save myself some money lol. Thanks
Adriel Paradise
Re: Gen 3 Hemi Critical Dimensions/Design Library Thread [Re: Adrielp] #2083647
05/31/16 10:13 PM
05/31/16 10:13 PM
LA360 Offline
LA360  Offline
I have some pdf files that have some of the block dimensions, but they too large to post as attachments. I might try a zip file
Dave Weber has a factory drawing for a 5.7L block, but I haven't asked for a copy. He is usually pretty darn busy
Alan Jones
Re: Gen 3 Hemi Critical Dimensions/Design Library Thread [Re: Adrielp] #2083735
05/31/16 11:33 PM
05/31/16 11:33 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Arrow racing has Block dimensions.
Mopar to the bone!!!
Re: Gen 3 Hemi Critical Dimensions/Design Library Thread [Re: 72Swinger] #2084300
06/01/16 09:41 PM
06/01/16 09:41 PM
LA360 Offline
LA360  Offline
http://www.arrowracingengines.com/geniiialuminumhemi.html
These are the pdf files I mentioned
They aren't a full workshop drawing, but still handy info
Alan Jones
Re: Gen 3 Hemi Critical Dimensions/Design Library Thread [Re: Adrielp] #2086432
06/05/16 02:41 PM
06/05/16 02:41 PM
cedar rapids, iowa
superhog88 Offline
superhog88  Offline
cedar rapids, iowa
what is the distance between intake ports center to center on the intake mounting surface
Re: Gen 3 Hemi Critical Dimensions/Design Library Thread [Re: superhog88] #2086489
06/05/16 04:54 PM
06/05/16 04:54 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
Should be equal to the bore spacing as long as there is no center offset
Adriel Paradise
