Re: REV-N-NATOR
[Re: stumpy]
#2079575
05/24/16 10:13 PM
05/24/16 10:13 PM
RapidRobert
Quick google search here comes up with all of this rev-=n-nator Stump that oughta keep him occupied for awhile!
Re: REV-N-NATOR
[Re: tweeter1]
#2079618
05/24/16 11:05 PM
05/24/16 11:05 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
They don't do anything special that you can't achieve with an MSD for much less money. They always compare these things to old-as-dirt Mopar controllers vs actual modern competitors.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: REV-N-NATOR
[Re: tweeter1]
#2080079
05/25/16 03:20 PM
05/25/16 03:20 PM
Secret Chimp
Eugene, Oregon
You can get a Street Fire with a built-in rev limiter for $160 nowadays. It has slightly less spark energy than a 6AL but that is really not going to matter for most motors. The Rev-N-Nator alone is $210.
Re: REV-N-NATOR
[Re: Secret Chimp]
#2080131
05/25/16 04:49 PM
05/25/16 04:49 PM
RapidRobert
My 2 cents: use a regular Mopar electronic dist/dial in the subsystems in order, initial/total/springs/vac can/get an HEI module/E coil/NGK or bosch plugs.
Re: REV-N-NATOR
[Re: RapidRobert]
#2080140
05/25/16 04:57 PM
05/25/16 04:57 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
My 2 cents: use a regular Mopar electronic dist/dial in the subsystems in order, initial/total/springs/vac can/get an HEI module/E coil/NGK or bosch plugs. I gutted a stock black ECU & mounted a MSD-83647 HEI module w/ rev limiter in it. Was like $100 iirc, works awesome. Also went with the blaster II coil & NGK plugs. No problems.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: REV-N-NATOR
[Re: DARTH V8Я]
#2080188
05/25/16 06:52 PM
05/25/16 06:52 PM
RapidRobert
Was like $100 iirc, works awesome. cant beat that
Re: REV-N-NATOR
[Re: tweeter1]
#2080282
05/25/16 09:56 PM
05/25/16 09:56 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Don't ever use bosche plugs in anything, I have seen tons of bad ones out of the box, last week I fixed two dakotas with misfires after someone did a tune up, a 4.7 and a 5.2 both had new bosche plugs, regular and plat+4. A quick swap to NGK fixes em for good.
Re: REV-N-NATOR
[Re: DARTH V8Я]
#2080297
05/25/16 10:17 PM
05/25/16 10:17 PM
Posts: 12,305 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My 2 cents: use a regular Mopar electronic dist/dial in the subsystems in order, initial/total/springs/vac can/get an HEI module/E coil/NGK or bosch plugs. I gutted a stock black ECU & mounted a MSD-83647 HEI module w/ rev limiter in it. Was like $100 iirc, works awesome. Also went with the blaster II coil & NGK plugs. No problems. How about a little more detail on this? The instructions call for installing the 83647 in a GM style HEI distributor. How do you use a Mopar style stock distributor? My Revenator is on it's way to R/T now due to a hi speed miss. So I am exploring my options. Thanks for any additional info!
Master, again and still
Re: REV-N-NATOR
[Re: DaveRS23]
#2080315
05/25/16 10:48 PM
05/25/16 10:48 PM
DARTH V8Я
Its a TRAP!
My 2 cents: use a regular Mopar electronic dist/dial in the subsystems in order, initial/total/springs/vac can/get an HEI module/E coil/NGK or bosch plugs. I gutted a stock black ECU & mounted a MSD-83647 HEI module w/ rev limiter in it. Was like $100 iirc, works awesome. Also went with the blaster II coil & NGK plugs. No problems. How about a little more detail on this? The instructions call for installing the 83647 in a GM style HEI distributor. How do you use a Mopar style stock distributor? My Revenator is on it's way to R/T now due to a hi speed miss. So I am exploring my options. Thanks for any additional info! Google how to install GM HEI on Mopar.. tons of info. there's this too: http://designed2drive.com/
Re: REV-N-NATOR
[Re: DaveRS23]
#2080348
05/25/16 11:20 PM
05/25/16 11:20 PM
RapidRobert
How about a little more detail on this? How do you use a Mopar style stock distributor? '75 & up HEI OE chebby black module (4 terminals). Or aftermarket one such as speedway motor dynamod but junkyard ones are cheap/reliable. the designed to drive piece to mount it looks nice but is very pricey, just cut a piece of 3/8 aluminum plate & shape it on your bench grinder (takes only minutes) & drill 2 holes to fit the two holes already in the bottom of the dist. Use some Radio Shack heat sink paste between HEI and plate. 12V to B terminal. coil neg to C terminal. W and G to dist pickup (I forget which is which on that but its in the archives). time it. EDIT to clarify, that 12V is to the coil positive primary
Re: REV-N-NATOR
[Re: tweeter1]
#2080437
05/26/16 12:57 AM
05/26/16 12:57 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Okay, I get it. I am shocked that this is the first I have heard of this conversion. I really like the idea of hiding the module in an old Mopar ECU housing and that the MSD unit has a rev-limiter.
For those of you that don't run a ballast with the GM style module, do you just tie the start and run circuits together?
Re: REV-N-NATOR
[Re: DaveRS23]
#2080441
05/26/16 01:03 AM
05/26/16 01:03 AM
RapidRobert
For those of you that don't run a ballast with the GM style module, do you just tie the start and run circuits together? Yes it dont get much press for some reason (& it is a chebby piece so it needs to be hidden). last one I did with an accell super coil, the big yellow beast with no ballast & it was a killer setup. you are supposed to run a ballast but you have ALOT of leeway on what you can and cannot get by with. yes tie the brown/blue together
Re: REV-N-NATOR
[Re: RapidRobert]
#2080448
05/26/16 01:21 AM
05/26/16 01:21 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
For those of you that don't run a ballast with the GM style module, do you just tie the start and run circuits together? Yes it dont get much press for some reason (& it is a chebby piece so it needs to be hidden). last one I did with an accell super coil, the big yellow beast with no ballast & it was a killer setup. you are supposed to run a ballast but you have ALOT of leeway on what you can and cannot get by with. yes tie the brown/blue together ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: REV-N-NATOR
[Re: DaveRS23]
#2081093
05/27/16 02:09 AM
05/27/16 02:09 AM
dogdays
The 4 pin GM HEI is designed to use 12 volts. No ballast resistor is required.
You could look it up.
One of the reasons that the GM HEI worked so well was that they used an E-core coil. The kind with the laminations on the outside. This let more of the energy get to the plugs.
I have posted about the E-core coil before. Price for a good one on Ebay is holding firm at about $12.00.
R.
Re: REV-N-NATOR
[Re: tweeter1]
#2081095
05/27/16 02:16 AM
05/27/16 02:16 AM
DARTH V8Я
Its a TRAP!
For the ballast I cut out the coils and solder in solid copper wire. Keepin it stealthy.
