Page 2 of 3 1 2 3
Re: REV-N-NATOR [Re: dogdays] #2081107
05/27/16 02:46 AM
05/27/16 02:46 AM
Dog which one is it. I wrote it down when you posted it before but it is buried in my notes
Re: REV-N-NATOR [Re: RapidRobert] #2081215
05/27/16 12:13 PM
05/27/16 12:13 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have the Rev-N-Nator on my street driven 70 Charger now for many years with no issues. I have seen none of the more horsepower or starts easier claims as they claim since my car always fires right up anyway but I do like the rev limiter feature just in case I ever over rev it.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: REV-N-NATOR [Re: 6PKRTSE] #2081236
05/27/16 12:43 PM
05/27/16 12:43 PM
I agree as it is just a fancy on/off switch for the coil pri current on the neg side. However it must open when the pickup tells it to/no electronic delay (pulled timing issue on some exp the orange boxes) and be capable of handling however much current that is flowing in that coil pri circuit as some coils/no ballast setups will flow more than others
Re: REV-N-NATOR [Re: RapidRobert] #2081296
05/27/16 02:38 PM
05/27/16 02:38 PM
dogdays Offline
dogdays  Offline
Reading through the RevNNator website I found a couple of clues to the huge hp gain they tested. the largest hp gain was on a bigblock with total timing set at 32 degrees. That's six degrees retarded from normal best power advance for B/RBs, which is 38 degrees. So a faster acting switch will act like the spark is advanced two degrees, adding more advance to an engine that clearly needs it.
The E-core coil that is easiest to find was used on all TFI (Thick Film Ignition) fords. For example, my 89 Taurus had one, Mustangs of the same year. See this link:
http://www.ebay.com/itm/261647237128?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Borg-Warner Select FD478.
R.
Re: REV-N-NATOR [Re: dogdays] #2081300
05/27/16 02:45 PM
05/27/16 02:45 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Wow good find! That is a pretty slick trick on their part, admittedly..
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: REV-N-NATOR [Re: tweeter1] #2081306
05/27/16 03:05 PM
05/27/16 03:05 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Never seen a 40 horse gain from +2 timing increase. Unless it was on PowerBlock TV... LMFAO.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: REV-N-NATOR [Re: dogdays] #2081512
05/27/16 09:40 PM
05/27/16 09:40 PM
thanks Dog, noted for sure this time
Re: REV-N-NATOR [Re: tweeter1] #2081687
05/28/16 04:45 AM
05/28/16 04:45 AM
victoria australia
O
OZRT4406 Offline
OZRT4406  Offline
O
victoria australia
anyone used the fbo ecu? thoughts?
Re: REV-N-NATOR [Re: Secret Chimp] #2081831
05/28/16 01:45 PM
05/28/16 01:45 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Originally Posted By Secret Chimp
They don't do anything special that you can't achieve with an MSD for much less money. They always compare these things to old-as-dirt Mopar controllers vs actual modern competitors.
I like the MDS stuff too but I think the Rev-n-ator is more for guys that want to keep the stock look. I always ran MSD in my race cars, my current street car has a Pertronix IgnitorIII billet distributor, it is literally a 2-wire hookup plus a power wire, and has a built-in rev limiter. It works great but it required grinding alot off the Eddy RPM cylinder head to get it to fit.
Re: REV-N-NATOR [Re: tweeter1] #2081920
05/28/16 05:44 PM
05/28/16 05:44 PM
Mn
The R/T Garage Offline
Mn
The RT Garage here.
Ask away about the Rev-n-nator.
Here is what the Rev-n-nator offers that msd does not:
1. Plug n play
2. Newest technology
3. Made in USA
4. If you ever did have an issue unlike msd you will be on the side of road waiting for a tow. Rev-n-nator just plug in a stock box in and get home without a tow.
5. Keeping your Mopar a Mopar with a stock look.
6. No need to rewire and hide a big red ugly box.
7. We normally average more torque and hp than msd, so pretty darn good for plug in play.
8. Great customer service to all our customers.
9. 3 yr warranty and MONEY BACK GAURENTEE
10. quality piece and good looks
!!. We now offer the complete pkg with a Matched Coil that out performs msd and accel Coil, also the awesome Fire Core hp Distributor which is perfect for The Rev-n-nator.
Re: REV-N-NATOR [Re: OZRT4406] #2081921
05/28/16 05:46 PM
05/28/16 05:46 PM
Mn
Mn
Depends on what you want.
A stock Mopar look or not.
Re: REV-N-NATOR [Re: DARTH V8Я] #2081924
05/28/16 05:49 PM
05/28/16 05:49 PM
Mn
Mn
Darth, The Rev-n-nator can add any where from a 10- 40 hp gain over the Chysler boxes...Orange, Chrome, Gold.
proves it everytime in the dyno challenges.
We never claimed to add 10-40 over msd,but in all dyno challenges we have equaled or exceeded msd.
Obviously, if you have a worn out motor or very low compression motor, that does not require any spark demand,you will see minimal horse power gain.
But still gaining Rev limiting feature and better run ability.
Re: REV-N-NATOR [Re: Secret Chimp] #2081929
05/28/16 05:58 PM
05/28/16 05:58 PM
Mn
Mn
So you are saying you have found ' glues '....those are small amount of dynos...we do not fake anything or twisted timing to get the hp gains.
Being we have developed this product and spend a lot of money on R & D, we know how this ICU works and how we produce so much more hp than most others.
It has to do with digital technology and the best of the best components, and producing a product made in the USA.
Now we offer, a matched Coil ( which is a 1.5 ohm compared to msd and accel at 0.7 ohm ) Fire Core hp Distributor , which is perfect match to the Rev-n-nator.
Re: REV-N-NATOR [Re: The R/T Garage] #2081955
05/28/16 07:33 PM
05/28/16 07:33 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Originally Posted By The R/T Garage
Darth, The Rev-n-nator can add any where from a 10- 40 hp gain depending on your engine application.
The hp gain is over any stock box including chrome, proves it everytime in the dyno challenges.
We never claimed to add 10-40 over msd, but we do average more hp and torque than an msd 6al
What gaps are you running, and what brand plugs? Thanks.
Re: REV-N-NATOR [Re: Secret Chimp] #2082236
05/29/16 11:50 AM
05/29/16 11:50 AM
Mn
Mn
Remember the Rev-n-nator is a speciality peice for the Mopar die hard guy and unlike Street fire, ours is made in the U.S.A. with much higher quality components.
And manufacturing in the U.S.A. does cost more.
But that being said we are still cheaper than many China made ignition systems out there such as msd when everything is said and done.
Re: REV-N-NATOR [Re: The R/T Garage] #2083012
05/30/16 08:24 PM
05/30/16 08:24 PM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
I'm sold on the Rev-n-ator. A pure stock racer racer recommended it to me. I bought one and and noticed immediate increased idle quality and sharp cranking spark. I pitched my chrome box to the scrap pile. I like the performance, the look and the rev limiting feature. up beer
1971 BS23H1B
Re: REV-N-NATOR [Re: DARTH V8Я] #2100566
06/29/16 02:43 PM
06/29/16 02:43 PM
Mn
Mn
We use a quality spark plug like NGK
Don't use Champion.
Re: REV-N-NATOR [Re: tx9cuda] #2100568
06/29/16 02:47 PM
06/29/16 02:47 PM
Mn
Mn
Very nice Cuda, TX9!
Glad your Rev-n-nator is kickin' butt and your havin' fun!
Re: REV-N-NATOR [Re: The R/T Garage] #2100579
06/29/16 03:17 PM
06/29/16 03:17 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
shock
Re: REV-N-NATOR [Re: tweeter1] #2101318
06/30/16 08:55 PM
06/30/16 08:55 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I had an issue with my something in my ignition system. Shot them a message since its was already a Friday late afternoon. Low and behold I got a phone call a few minutes later from RT Garage working to resolve the issue. Then my big issue was going through a pile of "like new" ECU's ( FBO, couple oranges, old black one) I already had just to find out they had all gone bad. Don't know why I even kept them. I haven't tested the rev limiter yet though, but I'm glad to know it is there especially being a 4 speed. I'm still hoping it jives with the FiTech EFI system I need to install next.
Page 2 of 3 1 2 3
