71 Master Cylinder Tag Samples #2073975
05/15/16 05:59 PM
05/15/16 05:59 PM
New Jersey Bada Bing
bremotorsports Offline OP
Looking for samples of 71 master cylinder ID tags similar to the attached photo, for the purposes of reproduction of an often missing item.
Must show the primary group numbers as follows:
1176
1178
1182
1184
Bill Rolik
bremotorsports@verizon.net
201-394-5533 Cellular
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2074131
05/15/16 09:41 PM
05/15/16 09:41 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Bill
I think I have a couple at home. I'll post them for you on Wednesday assuming I can find where I put them.
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2076017
05/18/16 06:36 PM
05/18/16 06:36 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Bill
Here is one that I have.
Hope this helps.
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2077589
05/21/16 11:02 AM
05/21/16 11:02 AM
Much appreciated!
Anyone else???
Thanks,
Bill Rolik
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2078024
05/22/16 12:20 AM
05/22/16 12:20 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I have this one.
Re: 71 Master Cylinder Tag Samples [Re: Mastershake340] #2078152
05/22/16 11:18 AM
05/22/16 11:18 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
I have my original off my master cylinder and one off an NOS cylinder
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2078158
05/22/16 11:28 AM
05/22/16 11:28 AM
Guys, this is great stuff!
Still looking for a 1184 (3461184), which is for 71 manual drum.
Anybody out there?
Thanks,
Bill Rolik
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2078406
05/22/16 07:16 PM
05/22/16 07:16 PM
SE PA
Born2Run Online content
Born2Run  Online Content
SE PA
Here ya go Bill. I have an NOS 3461184 M/C I bought many years ago for my 71 Challenger.
I just pulled it out of the box and took this pic ...
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2078478
05/22/16 10:26 PM
05/22/16 10:26 PM
Very interesting.
The 3461184 master cylinder is for manual drum only, yet your tag is stamped PWR for power. That does not add up. Perhaps later NOS pieces like yours (with the wider reservoir and unequal fluid cavities than the assembly line units)were calibrated to use with both manual and power?
Here are the applications:
3461176 71 B/E-Body Power Disc
3461178 71 A-Body Power Disc
3461182 71 B/E-Body Power Drum
3461184 71 B/E/A-Body Manual Drum
Does anyone have a 1184 tag that does NOT have PWR stamped on the end? This would probably be found on the assembly line and early NOS replacement units with the narrow reservoir that have both fluid cavities the same size.
Thanks,
Bill Rolik
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2078609
05/23/16 01:34 AM
05/23/16 01:34 AM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
I have a 71 Challenger R/T with 11 inch HD manual drums. The tag is marked 1183 with a large 31 on the end. The 31 matches my broadcast sheet. My car has a SPD of 520 (if it matters). Dual reservoir of equal sizes, bail wire cover retainer, with exits towards the drivers side inner fender.
I would love to get a repro of this tag.
-Mark
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2080273
05/25/16 09:43 PM
05/25/16 09:43 PM
Yes, it can be done for you in the near future, once I see all available original samples.
Thanks,
Bill Rolik
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2080411
05/26/16 12:24 AM
05/26/16 12:24 AM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
On my super track pack car, not original to the car
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2080413
05/26/16 12:26 AM
05/26/16 12:26 AM
Lost Title
Lost Title
NOS cylinder, date of 1/73 on the box
Re: 71 Master Cylinder Tag Samples [Re: skdmark] #2082323
05/29/16 02:14 PM
05/29/16 02:14 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
This is the parts book replacement cylinder for these applications. I would assume that the part/assembly supplied to the production line would have included master, lid, bail, pushrod, plastic gasket with rubber boot ready to be installed. Because the B/E use one pushrod and the A-body another I would suspect these were 2 different assemblies.
The number on the second line of these tags would appear to be a 10,000 day calendar date. Assuming this, the one Mark posted for his 71 challenger would look to be a date that falls in for the 71 model year. The letters A, B, C could mean a number of things, shift, batch of the day, which line, etc.
Mike Afflerbach
Re: 71 Master Cylinder Tag Samples [Re: cudaize] #2082940
05/30/16 06:06 PM
05/30/16 06:06 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Here's a tag from an NOS 3461182 master cylinder I have.
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2082965
05/30/16 06:56 PM
05/30/16 06:56 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Here's one I had laying around.
1176
4379A
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2082968
05/30/16 06:58 PM
05/30/16 06:58 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Sorry,this is a little better
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2086659
06/05/16 09:40 PM
06/05/16 09:40 PM
All very good info, and much appreciated.
I will investigate the 10,000 day calendar scenario. Very intriguing.
If there are any other samples out there, please do not hesitate to post them here.
Thanks,
Bill Rolik
Re: 71 Master Cylinder Tag Samples [Re: bremotorsports] #2089842
06/10/16 10:32 PM
06/10/16 10:32 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's a 1176 tag believed to be the original tag off a December 1971 St. Louis built '72 Road Runner/GTX.
If the four digit code at the bottom is a date code it translates to November 17, 1971 which would've been perfect for the car. Odd that the PWR is stamped 180° compared to the above samples.
