Re: 24 hours of LeMons
[Re: 68rrunner]
#2076377
05/19/16 10:42 AM
05/19/16 10:42 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The green Valiant was the only Mopar I saw, except for maybe a Neon. It is a blast, our car is a tad more racey than most. This is WAY more fun then drag racing for sure. I highly recommend it. LeMons is more laid back, Chumpcar is more competitive. If anybody needs info check the websites. Or if you are near a track, swing by and check it out. Most teams love to talk about their junk. here's the in-car when it was running good. in-car-cam
[Re: Mr.Yuck]
#2076847
05/20/16 12:05 AM
05/20/16 12:05 AM
Posts: 7 Virginia
C-MORE
Virginia
Thanks Mr. Yuck for bringing us here. I'm the one running the Green Valiant (225 /6) with the "Nautical handling package" Here's a writeup that has our previous race's results in it: http://www.roadkill.com/v6-mustangs-dominate-lemons-south-peugeot-504-diesel-not-much/The car: ![](http://www.roadkill.com/wp-content/uploads/2016/05/HF-3.jpg) We're in DIRE need of suspension improvements. The car is running F-body spindles/brakes, a stock six with an Offy intake/Holley 2bbl, and an open rear. I'm really looking to get a posi rear, sway bars, and stiffer T bars in before our upcoming races in the fall.
[Re: Mr.Yuck]
#2076937
05/20/16 02:59 AM
05/20/16 02:59 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
[Re: C-MORE]
#2076947
05/20/16 04:12 AM
05/20/16 04:12 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Thanks Mr. Yuck for bringing us here. I'm the one running the Green Valiant (225 /6) with the "Nautical handling package" Here's a writeup that has our previous race's results in it: http://www.roadkill.com/v6-mustangs-dominate-lemons-south-peugeot-504-diesel-not-much/The car: ![](http://www.roadkill.com/wp-content/uploads/2016/05/HF-3.jpg) We're in DIRE need of suspension improvements. The car is running F-body spindles/brakes, a stock six with an Offy intake/Holley 2bbl, and an open rear. I'm really looking to get a posi rear, sway bars, and stiffer T bars in before our upcoming races in the fall. How does that work with the budget?
[Re: C-MORE]
#2077015
05/20/16 10:34 AM
05/20/16 10:34 AM
Mr.Yuck
Brookeville, Md
Thanks Mr. Yuck for bringing us here. I'm the one running the Green Valiant (225 /6) with the "Nautical handling package" Here's a writeup that has our previous race's results in it: http://www.roadkill.com/v6-mustangs-dominate-lemons-south-peugeot-504-diesel-not-much/The car: ![](http://www.roadkill.com/wp-content/uploads/2016/05/HF-3.jpg) We're in DIRE need of suspension improvements. The car is running F-body spindles/brakes, a stock six with an Offy intake/Holley 2bbl, and an open rear. I'm really looking to get a posi rear, sway bars, and stiffer T bars in before our upcoming races in the fall. T-bars, front sway bar, and a good set of shocks will make a world of difference. We spun a bearing and didn't make the race Sunday.
[Re: C-MORE]
#2077144
05/20/16 03:22 PM
05/20/16 03:22 PM
Posts: 43 Santa Fe Springs, CA
Jon @ Hotchkis
We're in DIRE need of suspension improvements. The car is running F-body spindles/brakes, a stock six with an Offy intake/Holley 2bbl, and an open rear. I'm really looking to get a posi rear, sway bars, and stiffer T bars in before our upcoming races in the fall. Throwing this out there. If the car already has a front bar, get another stocker and strap them together. Should be cheaper and eaisier than sourcing a larger single that fits. ![](http://www.peachparts.com/shopforum/attachments/vintage-mercedes/124549d1411262621-double-swaybar-mbswaybara.jpg) With the /6 you probably wont need a posi once you get springs and sways under it. You'll have a bunch more traction on that inside rear tire.
Hotchkis Performance 8633 Sorensen Ave. Santa Fe Springs, CA 90670 Phone: 562-907-7757 x224 Fax: 562-907-7765
Hotchkis Performance East 9075 Highway 152 Mooresville, NC 28115 704-660-3060
[Re: Jon @ Hotchkis]
#2077242
05/20/16 07:07 PM
05/20/16 07:07 PM
Posts: 5,395 Pikes Peak Country
TC@HP2
Pikes Peak Country
Throwing this out there. If the car already has a front bar, get another stocker and strap them together. Should be cheaper and eaisier than sourcing a larger single that fits. ![](http://www.peachparts.com/shopforum/attachments/vintage-mercedes/124549d1411262621-double-swaybar-mbswaybara.jpg) With the /6 you probably wont need a posi once you get springs and sways under it. You'll have a bunch more traction on that inside rear tire. X2. I've done the double bar mount before. It does step things up significantly and does so with throw away parts.
[Re: C-MORE]
#2077355
05/20/16 10:15 PM
05/20/16 10:15 PM
Posts: 22,800 Bitopia
jcc
Bitopia
What bar sizes are you running in the pics?
#2077376
05/20/16 10:47 PM
05/20/16 10:47 PM
Posts: 7 Virginia
C-MORE
Virginia
We're in DIRE need of suspension improvements. The car is running F-body spindles/brakes, a stock six with an Offy intake/Holley 2bbl, and an open rear. I'm really looking to get a posi rear, sway bars, and stiffer T bars in before our upcoming races in the fall. Throwing this out there. If the car already has a front bar, get another stocker and strap them together. Should be cheaper and eaisier than sourcing a larger single that fits. With the /6 you probably wont need a posi once you get springs and sways under it. You'll have a bunch more traction on that inside rear tire. Great suggestion! Unfortunately the car has zero bars on it now, just lowered torsion adjusters, flipped rear spring perches, and basic silver kyb shocks.
