2000 ram1500 transmission O/D flutter #2075357
05/17/16 09:10 PM
05/17/16 09:10 PM
colorado
savoy64 Offline OP
savoy64  Offline OP
colorado
i have just done a frame swap where i left all the running gear and engine loom on the frame while i lifted up the body and did the swap---i had driven the donor unit for quite sometime and all was well---after the swap i noticed when OD was applied i would get a fluttering feel like fuel was lacking----did the diagnostic--showed low voltage and purge valve not grounded----swapped in the purge valve----diagnostic is clean---same effect---swapped the vehicle computers (both 2000 auto 2wd) same fluttering--diagnostic still clean------color me baffled....bob
Re: 2000 ram1500 transmission O/D flutter [Re: savoy64] #2075362
05/17/16 09:22 PM
05/17/16 09:22 PM
Elizabethtown, KY
6T9Hemi Offline
6T9Hemi  Offline
Elizabethtown, KY
Get some Dr. Tranny Instant Shutter Fix. You can get it from a local transmission shop or probably find it on line. It's in a red tube. It's basically like posi-traction additive. Works wonders.
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: 2000 ram1500 transmission O/D flutter [Re: savoy64] #2075398
05/17/16 10:18 PM
05/17/16 10:18 PM
colorado
savoy64 Offline OP
savoy64  Offline OP
colorado
i cant help feeling like i have done something because the donor unit was trouble free until i sabotaged it with a new and improved body....must look too sleek or something...bob
Re: 2000 ram1500 transmission O/D flutter [Re: savoy64] #2075399
05/17/16 10:19 PM
05/17/16 10:19 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I know the body controller has the VIN in it , not sure what else it is in and what happens if there is a mismatch somewhere ?
is the rear axle ratio the same between the 2 trucks ?
