Re: 2000 ram1500 transmission O/D flutter
[Re: savoy64]
#2075362
05/17/16 09:22 PM
05/17/16 09:22 PM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
Get some Dr. Tranny Instant Shutter Fix. You can get it from a local transmission shop or probably find it on line. It's in a red tube. It's basically like posi-traction additive. Works wonders.
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
[Re: savoy64]
#2075399
05/17/16 10:19 PM
05/17/16 10:19 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I know the body controller has the VIN in it , not sure what else it is in and what happens if there is a mismatch somewhere ?
is the rear axle ratio the same between the 2 trucks ?
