Can someone identify this 4 speed transmission
#2074941
05/17/16 04:21 AM
05/17/16 04:21 AM
Posts: 658 Dillsburg, PA
Wizard
Dillsburg, PA
What transmission do I have here.
Tail shaft numbers 099539
transmission stamped 0A181451 PP8333038 0159
On the body of trans C99129H
C-95664 Z
Thnks,
Wizard
Guns, God, and Country.
U.S. Veteran
Re: Can someone identify this 4 speed transmission
[Re: Wizard]
#2074944
05/17/16 04:54 AM
05/17/16 04:54 AM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
If the input shaft has thick splines (18 splines) it is a 440/Hemi transmission. If it has thinner splines (23 splines) it is a small block or 383 transmission. I am not up on the casting numbers but the 0 in the 0A181451 means 197 0Being a 1970 it should be a B/E body or A body not the older style B body only shown below. All this is assuming it hasn't been Frankensteined together over the years. This will help figure out what body type it is from Hope it helps.
[Re: Wizard]
#2075223
05/17/16 05:01 PM
05/17/16 05:01 PM
Wizard
Dillsburg, PA
Just counted the input splines and it is 23
U.S. Veteran
[Re: Wizard]
#2075286
05/17/16 07:05 PM
05/17/16 07:05 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Just counted the input splines and it is 23 It's from a 383 powered B body , should have 2 shifter mounts on the tailshaft.
[Re: JohnRR]
#2075530
05/18/16 01:16 AM
05/18/16 01:16 AM
IMGTX
Just counted the input splines and it is 23 It's from a 383 powered B body , should have 2 shifter mounts on the tailshaft. How do you figure it's a 383? Were you able to look up the numbers previously mentioned or is there a reason it couldn't be a small block tranny? I'm not saying you are wrong, I am just curious how you arrived at that so I will be better informed in the future.
[Re: IMGTX]
#2075562
05/18/16 01:44 AM
05/18/16 01:44 AM
JohnRR
U.S.S.A.
Just counted the input splines and it is 23 It's from a 383 powered B body , should have 2 shifter mounts on the tailshaft. How do you figure it's a 383? Were you able to look up the numbers previously mentioned or is there a reason it couldn't be a small block tranny? I'm not saying you are wrong, I am just curious how you arrived at that so I will be better informed in the future. I pulled it out of my backside mostly. But after looking at Barry's site ... to confirm the hunch my backside was giving me ... Hamtramack Historical ... there weren't any 318 4 speed B bodies built so that would mean it was behind a big block and the only big block with a 23 spline 833 is a 383 powered car, and only 4bbl equipped in 1970.
[Re: it's Bob]
#2075721
05/18/16 11:19 AM
05/18/16 11:19 AM
JohnRR
U.S.S.A.
Also same transmission LA or B engine, just the bellhousing would change. It's not as easy as that after the 1967 model year. The bearing retainer is different between a big block and a smallblock in 1970 ... that difference started for the 1968 model year when the Hemi 4 speed got the 308 front bearing and they were put behind the 440 which used the same bellhousing as a 383 ...
