Can someone identify this 4 speed transmission #2074941
05/17/16 04:21 AM
05/17/16 04:21 AM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
What transmission do I have here.
Tail shaft numbers 099539
transmission stamped 0A181451
PP8333038 0159
On the body of trans C99129H
C-95664 Z
Thnks,
Wizard
Guns, God, and Country. U.S. Veteran
Re: Can someone identify this 4 speed transmission [Re: Wizard] #2074944
05/17/16 04:54 AM
05/17/16 04:54 AM
IMGTX Offline
IMGTX  Offline
If the input shaft has thick splines (18 splines) it is a 440/Hemi transmission. If it has thinner splines (23 splines) it is a small block or 383 transmission.
I am not up on the casting numbers but the 0 in the 0A181451 means 1970
Being a 1970 it should be a B/E body or A body not the older style B body only shown below.
All this is assuming it hasn't been Frankensteined together over the years.
This will help figure out what body type it is from
Hope it helps.
Re: Can someone identify this 4 speed transmission [Re: Wizard] #2074958
05/17/16 08:01 AM
05/17/16 08:01 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
0A so it is from a 1970 B-body, but not a Charger.
Re: Can someone identify this 4 speed transmission [Re: Wizard] #2075223
05/17/16 05:01 PM
05/17/16 05:01 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Just counted the input splines and it is 23
Re: Can someone identify this 4 speed transmission [Re: Wizard] #2075286
05/17/16 07:05 PM
05/17/16 07:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's from a 383 powered B body , should have 2 shifter mounts on the tailshaft.
Re: Can someone identify this 4 speed transmission [Re: JohnRR] #2075530
05/18/16 01:16 AM
05/18/16 01:16 AM
IMGTX Offline
IMGTX  Offline
How do you figure it's a 383? Were you able to look up the numbers previously mentioned or is there a reason it couldn't be a small block tranny?
I'm not saying you are wrong, I am just curious how you arrived at that so I will be better informed in the future. up
Re: Can someone identify this 4 speed transmission [Re: IMGTX] #2075562
05/18/16 01:44 AM
05/18/16 01:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I pulled it out of my backside mostly.
But after looking at Barry's site ... to confirm the hunch my backside was giving me wink ... Hamtramack Historical ... there weren't any 318 4 speed B bodies built so that would mean it was behind a big block and the only big block with a 23 spline 833 is a 383 powered car, and only 4bbl equipped in 1970.
Re: Can someone identify this 4 speed transmission [Re: Wizard] #2075621
05/18/16 04:43 AM
05/18/16 04:43 AM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
Also same transmission LA or B engine, just the bellhousing would change.
Re: Can someone identify this 4 speed transmission [Re: it's Bob] #2075721
05/18/16 11:19 AM
05/18/16 11:19 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's not as easy as that after the 1967 model year.
The bearing retainer is different between a big block and a smallblock in 1970 ... that difference started for the 1968 model year when the Hemi 4 speed got the 308 front bearing and they were put behind the 440 which used the same bellhousing as a 383 ...
