UGL small block cams.. #2072182
05/12/16 06:45 PM
05/12/16 06:45 PM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
.. for a 48 degree block, can't seem to find any. Not sure if MP still makes them. So is there any other source? And what kind of $$$ am I looking at when all is said and done, thanks.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: UGL small block cams.. [Re: DARTH V8Я] #2072195
05/12/16 07:20 PM
05/12/16 07:20 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Comp cams ground 1 for me a couple yrs ago. Check with Bullit or Predator cams. I think my cam was around 425.00. Can't remember exactly.
Re: UGL small block cams.. [Re: DARTH V8Я] #2072214
05/12/16 07:57 PM
05/12/16 07:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
For a billet core, LSM can make you one
Re: UGL small block cams.. [Re: DARTH V8Я] #2072222
05/12/16 08:14 PM
05/12/16 08:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you know what type of 48* cam.. babbit, or 50mm or
what
EDIT
like Fast said.. LSM can build it
wave
Re: UGL small block cams.. [Re: DARTH V8Я] #2072224
05/12/16 08:22 PM
05/12/16 08:22 PM
Its a TRAP!
Its a TRAP!
babbit
Re: UGL small block cams.. [Re: DARTH V8Я] #2072235
05/12/16 08:55 PM
05/12/16 08:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By DARTH V8R
babbit
Ok.. so its like a stock type cam with different size
bearings
wave
Re: UGL small block cams.. [Re: MR_P_BODY] #2072241
05/12/16 09:13 PM
05/12/16 09:13 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Cam bearings are all the same size
Re: UGL small block cams.. [Re: DARTH V8Я] #2072297
05/12/16 10:43 PM
05/12/16 10:43 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I have a R1A block that takes 2" babbit bearings on all 5 cam journals, so if you find a source of UGL cams let me know.
Re: UGL small block cams.. [Re: 340_Dart] #2072309
05/12/16 10:51 PM
05/12/16 10:51 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Mancini had them for sale on eBay. So I bought 1. It arrived a week later, opened the box & found a flat tappet cam. [ Moparts Family Site - Keep it Friendly ]. Called them up & go a lame excuse that they may have them in a parts container out behind the shop. Said they were busy & didn't have time to search for them. I did get a refund.
Re: UGL small block cams.. [Re: 340_Dart] #2072310
05/12/16 10:51 PM
05/12/16 10:51 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
http://www.midwayperformance.com/predatorcams/
Call Danny tell him Brett sent you.
Had about 50 cores done 2 years ago for this stuff.
Re: UGL small block cams.. [Re: rickraw] #2072318
05/12/16 11:04 PM
05/12/16 11:04 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Are you sure it was a flat tappet cam? I ordered one of their cams from eBay also and got a UGL 60mm roller cam core. I have a 60mm block also, so I kept it even though it wasn't what I wanted. Was yours gun drilled through the shaft?
Re: UGL small block cams.. [Re: W5DART66] #2072321
05/12/16 11:11 PM
05/12/16 11:11 PM
Its a TRAP!
Its a TRAP!
Deal fell through on the block I was looking at. But still might go the Ritter route, 48 degree, 9.6 deck, 4.185 bore. May go W8's or Indy 360-1 48's.. all that fun stuff.
Re: UGL small block cams.. [Re: 340_Dart] #2072331
05/12/16 11:16 PM
05/12/16 11:16 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I know a flat tappet cam when I see one. It's painted gold between the lobes, I think it's a crane cam? It does have some numbers stamped on the back end, but I haven't checked on them. No cam card. It's drilled on the 2nd & 4th main with grooves.
Re: UGL small block cams.. [Re: DARTH V8Я] #2072343
05/12/16 11:28 PM
05/12/16 11:28 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Just asking... No need to get offensive😉. It sounds like a flat tappet cam. When I got the one I received I had to ask Brett what exactly I had received. It's different than any cam I had seen. Here's mine
Sounds like Mancini sent out whatever they could find on the shelf.
Re: UGL small block cams.. [Re: 340_Dart] #2072350
05/12/16 11:37 PM
05/12/16 11:37 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Sorry, no offense meant. It is a flat tappet cam of unknown lift or anything. They told me to keep it. I really have no use for it. The cam u have is what I wanted. I'm sure the mains could be ground down to 50mm. That's what my block is now.
Re: UGL small block cams.. [Re: DARTH V8Я] #2072748
05/13/16 05:19 PM
05/13/16 05:19 PM
So. Burlington, Vt.
So. Burlington, Vt.
Good plating between the lobes is usually how 8620 steel billet cores are.
