UGL small block cams..
#2072182
05/12/16 06:45 PM
05/12/16 06:45 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
.. for a 48 degree block, can't seem to find any. Not sure if MP still makes them. So is there any other source? And what kind of $$$ am I looking at when all is said and done, thanks.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: UGL small block cams..
[Re: DARTH V8Я]
#2072222
05/12/16 08:14 PM
05/12/16 08:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Do you know what type of 48* cam.. babbit, or 50mm or what EDIT like Fast said.. LSM can build it
[Re: rickraw]
#2072318
05/12/16 11:04 PM
05/12/16 11:04 PM
Posts: 1,745 Maryland
340_Dart
Maryland
Mancini had them for sale on eBay. So I bought 1. It arrived a week later, opened the box & found a flat tappet cam. [ Moparts Family Site - Keep it Friendly ]. Called them up & go a lame excuse that they may have them in a parts container out behind the shop. Said they were busy & didn't have time to search for them. I did get a refund. Are you sure it was a flat tappet cam? I ordered one of their cams from eBay also and got a UGL 60mm roller cam core. I have a 60mm block also, so I kept it even though it wasn't what I wanted. Was yours gun drilled through the shaft?
[Re: W5DART66]
#2072321
05/12/16 11:11 PM
05/12/16 11:11 PM
DARTH V8Я
Its a TRAP!
Deal fell through on the block I was looking at. But still might go the Ritter route, 48 degree, 9.6 deck, 4.185 bore. May go W8's or Indy 360-1 48's.. all that fun stuff.
[Re: DARTH V8Я]
#2072748
05/13/16 05:19 PM
05/13/16 05:19 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Good plating between the lobes is usually how 8620 steel billet cores are.
