Wet sump pan
#2069214
05/08/16 10:07 AM
05/08/16 10:07 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
I didn't want to hijack Andy's billet pan thread, but the discussion moved to pumping losses and the effect of main web windows on power. So lets talk wet sump pans: is bigger better in order vis-a-vie pumping losses? I have a Dakota, so there is no center link or k=member in the way, and I'm modifying a circle track pan (dropping the sump 3"). This thing will be huge but since it started as a circle track piece, it is boiler plate heavy.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Wet sump pan
[Re: poboyengineering]
#2069631
05/08/16 09:52 PM
05/08/16 09:52 PM
poboyengineering
pennsylvania
Cab, I have a full kick out and am looking at mounting options for a scraper. The best way seems to be welding tabs to the tube that let me put bolts in on that side. I have a pan evacuation system, but no vacuum pump. I cut this pan apart to rework the baffles from left turn to straight as well as lower the sump. I'm using trap doors to hold oil around the pickup.
Re: Wet sump pan
[Re: AndyF]
#2069749
05/08/16 11:48 PM
05/08/16 11:48 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Yes, I'm pretty sure most everyone will agree that bigger is better on a wet sump pan. The only trick is making sure that you have an actual sump for the oil to collect in at the bottom of the big pan.
I'm not sure if kickouts work on Mopar big block engines since the skirt is 3 inches deep. There are people who window the block to get a kickout and maybe that works for them. It certainly takes a bunch of time and money to do it.
For a wet sump dyno pan I usually run the sump about 12 inches deep like the one in this picture. With a deep pan like that my front tires would be in the air setting still.
Re: Wet sump pan
#2070007
05/09/16 12:02 PM
05/09/16 12:02 PM
Posts: 304 Florida
Mark Whitener
A pan with the deepest sump the chassis will allow will control the oil the best. The area around the pump or pump pickup needs to be relatively small, trap door divider close. and top plates to get the cover even closer to the pump/pickup will keep oil from sloshing up as much at the launch and at the shutdown.
Mark Whitener [url=www.racingfuelsystems.com[/url]
Re: Wet sump pan
#2070880
05/10/16 05:11 PM
05/10/16 05:11 PM
poboyengineering
pennsylvania
When done, mine won't be far from the picture Andy posted, but it's a small block. Don't have final dimensions yet, but it won't be 12 inches deep, more like 9". It will have plenty of volume, since the sump is 15 inches square.
Re: Wet sump pan
#2070895
05/10/16 05:40 PM
05/10/16 05:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I built this one.. its steel right now but I will build another in alum.. its 9.5 qts but I only run 8 qts... has trap doors, chambers and baffles
Re: Wet sump pan
#2071214
05/11/16 12:50 AM
05/11/16 12:50 AM
rowin4
After reading these postings I got thinking that it seems mopars are the only ones I have seen these real deep pans . I know back in the sixties there were some on chevy's but now that the cars are lower most run a dragster type pan or kick out type. Being that chevy cranks hang out of the bottom of the block to start with 3-4" , the 6" theory would mean that the oil level would start at 9-10" from the pan rail , then add on the rest of the pan for capacity. I know in a perfect world it would be better but most of us don't.
Re: Wet sump pan
#2071756
05/11/16 11:27 PM
05/11/16 11:27 PM
poboyengineering
pennsylvania
nice. what is the little brass guy above your drain plug?
Re: Wet sump pan
#2071761
05/11/16 11:33 PM
05/11/16 11:33 PM
MR_P_BODY
nice. what is the little brass guy above your drain plug? Looks like a temp sender.. I have one in the drain plug itself on both the engine and trans ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Wet sump pan
#2071762
05/11/16 11:36 PM
05/11/16 11:36 PM
poboyengineering
pennsylvania
didn't consider that one. makes sense. is yours on the race car or the Rampage, MrP?
Re: Wet sump pan
#2071774
05/11/16 11:48 PM
05/11/16 11:48 PM
MR_P_BODY
didn't consider that one. makes sense. is yours on the race car or the Rampage, MrP? On the Rampage.. I have 1 temp gauge for both of them... just flip a switch to read either ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Wet sump pan
#2071779
05/11/16 11:52 PM
05/11/16 11:52 PM
poboyengineering
pennsylvania
Trick! That will come in handy for Dragweek. Are you in this year?
Re: Wet sump pan
[Re: MR_P_BODY]
#2071782
05/11/16 11:55 PM
05/11/16 11:55 PM
Posts: 4,457 Washington
madscientist
Washington
I built this one.. its steel right now but I will build another in alum.. its 9.5 qts but I only run 8 qts... has trap doors, chambers and baffles Don't want to jack this thread but is that remote filter plumbed directly into the block or are you running some sort of adapter plate?
