Wet sump pan #2069214
05/08/16 10:07 AM
05/08/16 10:07 AM
pennsylvania
poboyengineering Offline OP
pennsylvania
I didn't want to hijack Andy's billet pan thread, but the discussion moved to pumping losses and the effect of main web windows on power.
So lets talk wet sump pans: is bigger better in order vis-a-vie pumping losses?
I have a Dakota, so there is no center link or k=member in the way, and I'm modifying a circle track pan (dropping the sump 3").
This thing will be huge but since it started as a circle track piece, it is boiler plate heavy.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Wet sump pan [Re: poboyengineering] #2069380
05/08/16 03:20 PM
05/08/16 03:20 PM
I remember being told at one of the old Mopar drag seminars that the oil level should be a minimum of six inches lower than any of the crankshaft rotating parts, IE rod caps or rod bolts , whatever is the lowest up
As far as pumping loss a crankshaft scraper and adequate oil drain back will help reduce the oil mass influensing the density of the rotating air mass in the crankcase area, liquids don't compress very wellwork Most of the current state of the art drag race wet sump oil pans for motors that the main webbing ends at the center of the main caps use huge oil pans with enormous sumps with kick outs on the passenger sides and not much oil in them work scope thumbs
Are you using a vacume pump? If not, why not?
Re: Wet sump pan [Re: poboyengineering] #2069387
05/08/16 03:32 PM
05/08/16 03:32 PM
AndyF Offline
AndyF  Offline
Yes, I'm pretty sure most everyone will agree that bigger is better on a wet sump pan. The only trick is making sure that you have an actual sump for the oil to collect in at the bottom of the big pan.
I'm not sure if kickouts work on Mopar big block engines since the skirt is 3 inches deep. There are people who window the block to get a kickout and maybe that works for them. It certainly takes a bunch of time and money to do it.
For a wet sump dyno pan I usually run the sump about 12 inches deep like the one in this picture.
Re: Wet sump pan [Re: poboyengineering] #2069428
05/08/16 05:01 PM
05/08/16 05:01 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
bigger is better when you have the clearance,when it's limited or you just want extra insurance just add a 3 quart accusump.
Re: Wet sump pan [Re: poboyengineering] #2069631
05/08/16 09:52 PM
05/08/16 09:52 PM
pennsylvania
pennsylvania
Cab, I have a full kick out and am looking at mounting options for a scraper. The best way seems to be welding tabs to the tube that let me put bolts in on that side.
I have a pan evacuation system, but no vacuum pump.
I cut this pan apart to rework the baffles from left turn to straight as well as lower the sump. I'm using trap doors to hold oil around the pickup.
Re: Wet sump pan [Re: poboyengineering] #2069645
05/08/16 10:01 PM
05/08/16 10:01 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I had one custom built a while back. I wanted a built in pickup with internal baffles, scraper with windage tray. It is shallow with a rather large kickout. Fit's the car nice and holds 12 qt's. I've been happy with it.
Re: Wet sump pan [Re: poboyengineering] #2069691
05/08/16 10:47 PM
05/08/16 10:47 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Wow, that pan sure is a beauty.
[image][/image]
Re: Wet sump pan [Re: AndyF] #2069749
05/08/16 11:48 PM
05/08/16 11:48 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
With a deep pan like that my front tires would be in the air setting still.
Re: Wet sump pan [Re: poboyengineering] #2070007
05/09/16 12:02 PM
05/09/16 12:02 PM
Mark Whitener Offline
A pan with the deepest sump the chassis will allow will control the oil the best. The area around the pump or pump pickup needs to be relatively small, trap door divider close. and top plates to get the cover even closer to the pump/pickup will keep oil from sloshing up as much at the launch and at the shutdown.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Wet sump pan [Re: poboyengineering] #2070615
05/10/16 09:11 AM
05/10/16 09:11 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Like someone said earlier, a skirted Block like a Mope isn't going to benefit from a big bulge on the side of the pan like a Chevy or ford would. Kick outs in the sump are OK for more oil capacity without going lower, but that's about it.
When I finish my next predator engine, I'll be testing it with a huge wet system, then with a complete Dailey dry system to see if power changes. I don't think it'll be anything if vacuum is similar. The only thing I really hope to gain is less aerated oil for the bearings
Re: Wet sump pan [Re: poboyengineering] #2070880
05/10/16 05:11 PM
05/10/16 05:11 PM
pennsylvania
pennsylvania
When done, mine won't be far from the picture Andy posted, but it's a small block. Don't have final dimensions yet, but it won't be 12 inches deep, more like 9". It will have plenty of volume, since the sump is 15 inches square.
Re: Wet sump pan [Re: poboyengineering] #2070895
05/10/16 05:40 PM
05/10/16 05:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I built this one.. its steel right now but I will
build another in alum.. its 9.5 qts but I only run
8 qts... has trap doors, chambers and baffles
wave
Re: Wet sump pan [Re: poboyengineering] #2071214
05/11/16 12:50 AM
05/11/16 12:50 AM
rowin4 Offline
rowin4  Offline
After reading these postings I got thinking that it seems mopars are the only ones I have seen these real deep pans . I know back in the sixties there were some on chevy's but now that the cars are lower most run a dragster type pan or kick out type. Being that chevy cranks hang out of the bottom of the block to start with 3-4" , the 6" theory would mean that the oil level would start at 9-10" from the pan rail , then add on the rest of the pan for capacity. I know in a perfect world it would be better but most of us don't.
Re: Wet sump pan [Re: poboyengineering] #2071299
05/11/16 08:23 AM
05/11/16 08:23 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I made this pan to match the gap in my K frame. Holds 12 Quarts but I still run an Accusump for safety. The motor has a crank scraper & Vac pump & with the perferated steel surge baffles it seems to control the oil real well.
Re: Wet sump pan [Re: poboyengineering] #2071756
05/11/16 11:27 PM
05/11/16 11:27 PM
pennsylvania
pennsylvania
nice. what is the little brass guy above your drain plug?
Re: Wet sump pan [Re: poboyengineering] #2071761
05/11/16 11:33 PM
05/11/16 11:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks like a temp sender.. I have one in the drain plug itself
on both the engine and trans
wave
Re: Wet sump pan [Re: poboyengineering] #2071762
05/11/16 11:36 PM
05/11/16 11:36 PM
pennsylvania
pennsylvania
didn't consider that one. makes sense.
is yours on the race car or the Rampage, MrP?
Re: Wet sump pan [Re: poboyengineering] #2071774
05/11/16 11:48 PM
05/11/16 11:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On the Rampage.. I have 1 temp gauge for both of them...
just flip a switch to read either
wave
Re: Wet sump pan [Re: poboyengineering] #2071779
05/11/16 11:52 PM
05/11/16 11:52 PM
pennsylvania
pennsylvania
Trick! That will come in handy for Dragweek. Are you in this year?
Re: Wet sump pan [Re: MR_P_BODY] #2071782
05/11/16 11:55 PM
05/11/16 11:55 PM
Washington
madscientist Offline
Washington
wave
Don't want to jack this thread but is that remote filter plumbed directly into the block or are you running some sort of adapter plate?
