Hondabond HT for intake runners on 440 head swap #2071497
05/11/16 03:38 PM
05/11/16 03:38 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
I am installing some newly purchased Eddy performer heads I found here on Moparts and was advised by the machine shop that pressure tested them to use Hondabond HT on the intake runners and to not worry about copper spray on the fel-pro head gasket. He runs a busy shop with good reviews so I will take his advice. Any other real world experience?
Re: Hondabond HT for intake runners on 440 head swap [Re: p d'ro] #2071515
05/11/16 04:10 PM
05/11/16 04:10 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Honda bond is excellent stuff for this application unlike most RTV's it withstands gasoline.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Hondabond HT for intake runners on 440 head swap [Re: p d'ro] #2071526
05/11/16 04:32 PM
05/11/16 04:32 PM
and to not worry about copper spray on the fel-pro head gasket. He runs a busy shop with good reviews. Any other real world experience?
on FP blue composition-dont use it. on steel shim-use it. yes HB has a widespread good rep & I just got a tube recently, ain't used it yet
Re: Hondabond HT for intake runners on 440 head swap [Re: p d'ro] #2071588
05/11/16 06:29 PM
05/11/16 06:29 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Ok.. Thanks to all. Will keep the Hondabond, use ultra black on the end rails, and no spray on the 8519PT...
I will cross my fingers.
He also said OK to reuse my 915 head rocker studs as I am reusing the stock rockers. I bought ARP head and intake manifold bolts.
Re: Hondabond HT for intake runners on 440 head swap [Re: p d'ro] #2071692
05/11/16 09:39 PM
05/11/16 09:39 PM
I have used Permatex 99MA "high tack" the thin red spray (glue/sealant) in the purple can on Felpro blues. A thin/light/even coat especially around the cooling holes. that stuff is very good for sealing and glueing gaskets in place. I know Felpro says use em dry/as is
Re: Hondabond HT for intake runners on 440 head swap [Re: p d'ro] #2071840
05/12/16 01:07 AM
05/12/16 01:07 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I don't use anything on the tins other than RTV in the corners, no one I know does. Using the RTV around the ports won't hurt, should only help, but its probably not needed and will just create a mess to clean up if you take it apart.
Honda bond is good stuff.
