Re: Hondabond HT for intake runners on 440 head swap
[Re: p d'ro]
#2071515
05/11/16 04:10 PM
05/11/16 04:10 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Honda bond is excellent stuff for this application unlike most RTV's it withstands gasoline.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: p d'ro]
#2071526
05/11/16 04:32 PM
05/11/16 04:32 PM
RapidRobert
and to not worry about copper spray on the fel-pro head gasket. He runs a busy shop with good reviews. Any other real world experience? on FP blue composition-dont use it. on steel shim-use it. yes HB has a widespread good rep & I just got a tube recently, ain't used it yet
[Re: p d'ro]
#2071692
05/11/16 09:39 PM
05/11/16 09:39 PM
RapidRobert
I have used Permatex 99MA "high tack" the thin red spray (glue/sealant) in the purple can on Felpro blues. A thin/light/even coat especially around the cooling holes. that stuff is very good for sealing and glueing gaskets in place. I know Felpro says use em dry/as is
[Re: p d'ro]
#2071840
05/12/16 01:07 AM
05/12/16 01:07 AM
Posts: 5,161 CT
GTX MATT
CT
I don't use anything on the tins other than RTV in the corners, no one I know does. Using the RTV around the ports won't hurt, should only help, but its probably not needed and will just create a mess to clean up if you take it apart.
Honda bond is good stuff.
