Rough running 94 Ram. #2069712
05/08/16 11:13 PM
05/08/16 11:13 PM
Missouri
StrokerPost Offline OP
Missouri
A friend's son has a 94 Ram with a 360. The problem is that as it comes up to temp (water) it starts running really rough he says. He said it runs fine until its warm then goes rough. He's had it to 2 shops and they couldn't figure it out. I know he tried a new coil, but no change. Any ideas? Oh yes, I believe he said they tried a new computer too with no change.
Thanks,
Ken.
Re: Rough running 94 Ram. [Re: StrokerPost] #2069718
05/08/16 11:18 PM
05/08/16 11:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
o2 sensors. Try unplugging them and see if it still does it.
Re: Rough running 94 Ram. [Re: HotRodDave] #2069741
05/08/16 11:37 PM
05/08/16 11:37 PM
Missouri
Missouri
Thanks, Ill pass it on. He also tried a new computer with no change.
Re: Rough running 94 Ram. [Re: StrokerPost] #2069851
05/09/16 01:49 AM
05/09/16 01:49 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
try a new crank position sensor
my ladder of success is missing some rungs
Re: Rough running 94 Ram. [Re: rhad] #2070287
05/09/16 08:24 PM
05/09/16 08:24 PM
chicago il
I
ides Offline
ides  Offline
I
chicago il
try the egr valve my 95 did the years ago.unplugged it and has run fine ever since
Re: Rough running 94 Ram. [Re: StrokerPost] #2070328
05/09/16 09:32 PM
05/09/16 09:32 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Does it use oil? Could be the intake gaskets leaking.
Re: Rough running 94 Ram. [Re: StrokerPost] #2071276
05/11/16 03:29 AM
05/11/16 03:29 AM
Guitar Jones Offline
Are there any codes? Have the shop take a close look at the coolant temperature sensor reading. I've seen the wire insulation become brittle, break off and short together making the PCM think the engine is 40 degrees below zero. Causes an extremely rich condition.
Re: Rough running 94 Ram. [Re: Guitar Jones] #2071867
05/12/16 02:08 AM
05/12/16 02:08 AM
Missouri
Missouri
Unfortunately I know very little about it, only what his dad told me, but I will pass this along. Thanks guys.
Ken.
Re: Rough running 94 Ram. [Re: StrokerPost] #2072039
05/12/16 02:11 PM
05/12/16 02:11 PM
Also if the thermostat is stuck partially open the engine takes too long to get to operating temp. This causes the PCM to keep adding fuel because the engine is cold. Then once it gets to temp the adaptives are too far out to correct and it continues to run rich.
