Re: Rough running 94 Ram.
[Re: StrokerPost]
#2069718
05/08/16 11:18 PM
05/08/16 11:18 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
o2 sensors. Try unplugging them and see if it still does it.
[Re: HotRodDave]
#2069741
05/08/16 11:37 PM
05/08/16 11:37 PM
Posts: 6,847 Missouri
StrokerPost
Missouri
o2 sensors. Try unplugging them and see if it still does it. Thanks, Ill pass it on. He also tried a new computer with no change.
[Re: StrokerPost]
#2069851
05/09/16 01:49 AM
05/09/16 01:49 AM
Posts: 954 garnett kansas
rhad
garnett kansas
try a new crank position sensor
my ladder of success is missing some rungs
[Re: StrokerPost]
#2070328
05/09/16 09:32 PM
05/09/16 09:32 PM
Posts: 8,164 Plymouth, MI
Blusmbl
Plymouth, MI
Does it use oil? Could be the intake gaskets leaking.
[Re: StrokerPost]
#2071276
05/11/16 03:29 AM
05/11/16 03:29 AM
Guitar Jones
Are there any codes? Have the shop take a close look at the coolant temperature sensor reading. I've seen the wire insulation become brittle, break off and short together making the PCM think the engine is 40 degrees below zero. Causes an extremely rich condition.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2071867
05/12/16 02:08 AM
05/12/16 02:08 AM
StrokerPost
Missouri
Are there any codes? Have the shop take a close look at the coolant temperature sensor reading. I've seen the wire insulation become brittle, break off and short together making the PCM think the engine is 40 degrees below zero. Causes an extremely rich condition. Unfortunately I know very little about it, only what his dad told me, but I will pass this along. Thanks guys. Ken.
[Re: StrokerPost]
#2072039
05/12/16 02:11 PM
05/12/16 02:11 PM
Guitar Jones
Also if the thermostat is stuck partially open the engine takes too long to get to operating temp. This causes the PCM to keep adding fuel because the engine is cold. Then once it gets to temp the adaptives are too far out to correct and it continues to run rich.
