Page 2 of 3 1 2 3
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2069139
05/08/16 01:36 AM
05/08/16 01:36 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
Thanks for all the ideas guys. I talked to a buddy, he said they had to cut their cable so there was just enough slack when the engine would move it wouldn't rip the cable off the firewall. So I'm going to try shortening the cable some more between the bracket and firewall.
If that doesn't work I may just go the route hemi-itis did. Do you recall the part number? Does it actually mount in the stock holes?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Dominator throttle with stock pedal, can't get WOT [Re: slantzilla] #2069174
05/08/16 04:12 AM
05/08/16 04:12 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By slantzilla
Is the lever on the pedal itself bent? Can you bend it so the pedal itself sits higher and has more travel?
Not a Dominator expert, didn't even stay at a Holiday Inn either.....
This is what I did as I use a Lokar throttle cable and like it but even with my 850 DP I could not get WOT. So I bent the gas pedal rod on the floor as I bent it up some for more pedal travel and it worked good. Ron
Re: Dominator throttle with stock pedal, can't get WOT [Re: 383man] #2069260
05/08/16 12:01 PM
05/08/16 12:01 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
i agree I have done this on 5 or 6 different cars....grab the pedal side and pull up you will be surprised on how easy it bends. Then after rejust your cable so that you're not killing the shafts the carburetor
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2069267
05/08/16 12:14 PM
05/08/16 12:14 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
NO,,,,,,,,,,and NO shruggy
When you look at their website,you'll see several different versions.You'll know what's will work for you.MY crew cheif raised the new pedal off the floor to insure full movement.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2069342
05/08/16 01:55 PM
05/08/16 01:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That rear hole goes below the throttle bracket at WOT. If I put the throttle stud there it will stop the throttle from going wide open as well.
I use photo bucket on my phone to post pics on here. It's actually pretty easy.
I had to clearance my bracket a bit for the same reasons........
Re: Dominator throttle with stock pedal, can't get WOT [Re: Thumperdart] #2069369
05/08/16 03:04 PM
05/08/16 03:04 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
try using only one spring, went through this too. I also unbolted the top of the gas pedal and put a shim in the top
kinda like bending the arm deal
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Dominator throttle with stock pedal, can't get WOT [Re: Stroker Scamp] #2069401
05/08/16 03:59 PM
05/08/16 03:59 PM
Menomonee Falls
Menomonee Falls
Gotta use 2 springs otherwise the track won't allow me to run.
I'm gonna try bending the gas pedal this afternoon when I get back out to the shop and readjust the cable see how that works.
SDG Motorsports
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2069706
05/08/16 11:03 PM
05/08/16 11:03 PM
Menomonee Falls
Menomonee Falls
Well I got it to open almost all the way. The problem I see is it's already going back down, so I'd have to some how lower the bracket. They have stupid aluminum spacers you have to put under the bracket to clear the accelerator pump arm. Which raises the bracket up .250... Stupid bandaid in my opinion, why not space the front and angle it properly so the rear can sit without a spacer???? Anyway almost solved my dilemma.
The primary is almost all the way open, but the secondary is about 75-80°. Hard to tell in the picture but you can tell it's not even close to the primary. Am I being too critical, or should they both be almost 90°?
SDG Motorsports
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2069719
05/08/16 11:21 PM
05/08/16 11:21 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Take the spacer out from under the rear stud or put a shorter one in its place.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2069735
05/08/16 11:32 PM
05/08/16 11:32 PM
Menomonee Falls
Menomonee Falls
That's exactly what I did, that aluminum is flexible, I just hope it doesn't crack from the flex and vibration.
On a side note like other guys stated above its very easy to bend the pedal, with that being said what's to stop it from bending back? Do you have to tweak it every now and then? Thinking I should maybe just put an aftermarket pedal in.
SDG Motorsports
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2069773
05/09/16 12:07 AM
05/09/16 12:07 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have the same throttle bracket, I went to the top hole and put spring return on lower hole to get it to work.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2069777
05/09/16 12:13 AM
05/09/16 12:13 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Can you put bolts from the adapter to the manifold, and put studs through the carb and adapter long enough to stick out the bottom and mount the throttle bracket from underneath?
[image][/image]
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2069802
05/09/16 12:47 AM
05/09/16 12:47 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I am waiting on my Allstar throttle bracket to show up but I installed the cable today, for the pedal to rest in the same spot it could from the factory I had to trim the thread off the through firewall bulkhead. The pedal was hitting that before the stopper
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2069818
05/09/16 01:04 AM
05/09/16 01:04 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The force it will take to bend the pedal is far greater than what the throttle blades and return springs will exert on it so you should be good to go. Just make sure that there is a positive stop under the pedal that corresponds to WOT so it doesn't go past.
Kevin
Re: Dominator throttle with stock pedal, can't get WOT [Re: WHITEDART] #2070318
05/09/16 09:24 PM
05/09/16 09:24 PM
Wedge Land
MBigBlock Offline
MBigBlock  Offline
Wedge Land
Originally Posted By WHITEDART
The simple way is reach down and bend the pedal arm up away from the floor...this is what I do
The good ol' reach down and bend the valiant pedal upwards trick to gain more travel laugh until it snaps off and your idling your way back to a buddies workshop to weld it back on
Re: Dominator throttle with stock pedal, can't get WOT [Re: Twostick] #2070327
05/09/16 09:31 PM
05/09/16 09:31 PM
Wedge Land
MBigBlock Offline
MBigBlock  Offline
Wedge Land
Kevin
Me remembering back in the day idling my early A-body to a workshop, all dressed nice and with a mig welder in hand crouched under the dash welding my pedal back on and hoping the carpet didn't catch on fire disagrees with your theory wave
If ya going to bend your pedals up for more travel, which is a Mopar past time, weld some steel to it to strengthen it or it can snap off eventually
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2070489
05/10/16 12:59 AM
05/10/16 12:59 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I spent money on the NOS brand version of that throttle cable setup with the solenoid brackets. Same thing, hit the pump arms and was in the way of the fuel lines. Nice idea, poor execution.
When stuff happens like this I wonder how many of these are collecting dust because of the retarded design.
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2070504
05/10/16 01:19 AM
05/10/16 01:19 AM
Menomonee Falls
Menomonee Falls
I called jegs just to ask their opinion, and wouldn't you know, they'd never heard of this before. I'm the first guy. I have very hard time believing this.
SDG Motorsports
Re: Dominator throttle with stock pedal, can't get WOT [Re: Jeremiah] #2070513
05/10/16 01:30 AM
05/10/16 01:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A spacer under the rear of the cable
mount will only make your issue worse..
you can see in the pic its pulling straight
from the cable to the carb mount point.. if
you move to the upper hole you will need to
get more travel.. bend the arm inside if you
want or add some length to the top of the pedal
EDIT
I built about 50 or so pedals for production cars
Also... undo the cable at the carb.. push the arm
all the way open.. does it open both blades fully
wave
Re: Dominator throttle with stock pedal, can't get WOT [Re: DemonDust] #2070516
05/10/16 01:32 AM
05/10/16 01:32 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Lies! All lies!
I am really temped to make my own that fit. What's another $100 down the drain to blu collar guys like us, right?
Page 2 of 3 1 2 3
