Re: 8mm Wires for electronic Ignition
[Re: sixpackman]
#2070120
05/09/16 03:07 PM
05/09/16 03:07 PM
RapidRobert
I cant say that I have heard of 8mm wires (dont mean they ain't out there tho!). would there be a problem wiring it with regular adequate gauge wiring & on the ECU pentastar connector one of the wires is black/yellow (to coil neg) and another one is grey/black (to the male terminal on the body half of the zigzag connector for the dist pickup). EDIT opps my bad you are speaking of plug wires (I knew I was missing something!)
[Re: sixpackman]
#2070121
05/09/16 03:07 PM
05/09/16 03:07 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I think a member Sunroof GTX has them.taylor also should make 8 mm blacks.ive run taylors for the last 20 years with no problems.last set I ran for almost 20 years.Changed them because they were looking ratty.rocky
Chrysler Firepower
[Re: sixpackman]
#2070206
05/09/16 05:38 PM
05/09/16 05:38 PM
therocks
Niles , Ohio
Taylors with 2 inc TTIS and no problems.My kid ran 2 1/8 tubes with them.Also ran then on 4 small blocks ,Durango,and my 57 chrysler.Rocky
Chrysler Firepower
[Re: sixpackman]
#2070407
05/09/16 10:59 PM
05/09/16 10:59 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
We have them. Let me know what your options are. Headers, distributor, coil? Thanks
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sixpackman]
#2070701
05/10/16 12:07 PM
05/10/16 12:07 PM
RapidRobert
Got talking with them and was told that I CAN'T run them with electronic Ignition because they are to small and not rated for it. They dont want to make it right & I understand that (not agreeing tho) but what a lame excuse they put on you, they know better than that, go after em!
[Re: sixpackman]
#2071168
05/11/16 12:06 AM
05/11/16 12:06 AM
sunroofgtx
Cleveland
Mancini has them. They are sponsors here..
[Re: sixpackman]
#2071222
05/11/16 12:56 AM
05/11/16 12:56 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
My car is completely stock. I bought date coded correct wires for it. Had a problem with them. When returning them I got sent to the company who made the wires. Got talking with them and was told that I CAN'T run them with electronic Ignition because they are to small and not rated for it. Their claim is what falls out the south end of a north bound horse. Stock electronic ignition is no more intense than stock points ignition. Just less stuff to wear and more reliable is all. Key word is stock. No claims are being made in regards to CD or other aftermarket ignitions.
