Re: Machinists repair advice
[Re: RO23dave]
#2069868
05/09/16 02:19 AM
05/09/16 02:19 AM
RapidRobert
can you just use a regular bolt (is there room/flat area to use a nut on the back side of it)
[Re: RO23dave]
#2069976
05/09/16 11:15 AM
05/09/16 11:15 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Yes you can use the helicoil, the tab is there to allow the tool to install the helicoil, you still need to break it off but a pair of needle nose pliers on the tab side of the hole makes it easy.
[Re: RO23dave]
#2070016
05/09/16 12:23 PM
05/09/16 12:23 PM
Posts: 75,034 U.S.S.A.
JohnRR
U.S.S.A.
Yes a helicoil will work find there , I done a couple of 727's were I had to helicoil about 10 holes because they were stripped out over the years.
[Re: RO23dave]
#2070811
05/10/16 02:48 PM
05/10/16 02:48 PM
dogdays
Permatex Form-A-Thread. I used it on a stripped hole on a frying pan with great success. Clean Clean Clean and be sure to use the release agent on the bolt.
Helicoils require drilling and tapping with the next size tap, although it's a special tap. If you don't know someone who uses Helicoils regularly, the price will shock you when you go to get a kit. I found the best deals on Ebay.
Although Helicoils are better, the Form-A-Thread is surprisingly strong and should be considered.
R.
[Re: RO23dave]
#2070830
05/10/16 03:12 PM
05/10/16 03:12 PM
Supercuda
About to go away
About to go away
up yours
Assuming it's 3/8-16, IIRC, then it's $20 for the kit. http://www.summitracing.com/parts/hll-5521-6You will also need the correct 25/64" drill bit if you do not have it.
[Re: Supercuda]
#2070845
05/10/16 03:36 PM
05/10/16 03:36 PM
Posts: 25,836 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Starter threads are 7/16"-14. Bottom hole gets a stud, not a bolt.
