Convert dash lamps to LED #2069402
05/08/16 04:01 PM
05/08/16 04:01 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Can the stock dash lamps, gauge, turn signals etc be easily converted to LED in a E body?
Re: Convert dash lamps to LED [Re: Dr Dave] #2069456
05/08/16 05:55 PM
05/08/16 05:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do a google custom search(next to www.moparts.com top of this page)for led dash lights.Everything you will need to know. up
Re: Convert dash lamps to LED [Re: Dr Dave] #2069985
05/09/16 11:27 AM
05/09/16 11:27 AM
Ohio
jimm69 Offline
jimm69  Offline
Ohio
I have a B body and just replaced my 194 bulbs with LED's that I got at local auto parts store. They are not the cheapest but the dash is much brighter now. easy replacement. just plugs into same socket with no modifications
Re: Convert dash lamps to LED [Re: Dr Dave] #2070046
05/09/16 01:17 PM
05/09/16 01:17 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I just did this recently with my A body rally dash. Got the 194 LEDs at Walmart.
Much brighter now.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Convert dash lamps to LED [Re: 19swinger70] #2070063
05/09/16 01:52 PM
05/09/16 01:52 PM
FRANCE, Paris
Chal340 Offline
Chal340  Offline
FRANCE, Paris
I did this last year, I replaced all the bulbs by Led.
Found them here :
Superbrightleds for Ebodies
70 Challenger, A66, 340 ci
Re: Convert dash lamps to LED [Re: Dr Dave] #2070227
05/09/16 06:13 PM
05/09/16 06:13 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
I bought 100-pack off eBay (20 Each - Red, Blue, Yellow, Green, White) of 194s for my 74 Duster. I think they were $14 shipped. Did all the dash lights and the side marker bulbs too. There are a couple misc. bulbs that were not 194s under the dash, so I have to get replacements for them. Just do a search for them on eBay. Much cheaper than the stores...and I got spares for other projects...
When you work on Spaceships for a living, how bad can a workday be?
Re: Convert dash lamps to LED [Re: Dr Dave] #2070239
05/09/16 06:42 PM
05/09/16 06:42 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Awesome, thanks all! I was thinking you needed a resistor or something like that spliced in to make them work (turn signals). Has anyone played with headlights?
Re: Convert dash lamps to LED [Re: Dr Dave] #2070241
05/09/16 06:45 PM
05/09/16 06:45 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The resistors should already be in the bulbs so you don't have to worry about that. You will need to run the electronic flashers though. The old style flashers won't work since the LED bulbs use a lot less power.
Re: Convert dash lamps to LED [Re: Dr Dave] #2070329
05/09/16 09:32 PM
05/09/16 09:32 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I cant get dim enough dash lights at night...bright dash is blinding to me. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Convert dash lamps to LED [Re: astjp2] #2070824
05/10/16 03:03 PM
05/10/16 03:03 PM
dogdays Offline
dogdays  Offline
I have the same problem with my daily driver. I am thinking of adding a resistor in series to knock down the voltage past what the dimmer does.
Also, do the lights run off the voltage "regulator" on the dash or by 12VDC?
R.
Re: Convert dash lamps to LED [Re: Dr Dave] #2070850
05/10/16 03:47 PM
05/10/16 03:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
12v regulated by the dimmer.
Re: Convert dash lamps to LED [Re: burdar] #2071655
05/11/16 08:11 PM
05/11/16 08:11 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Superbrightleds.com has a resistor you put between the pos and neg leads to each of your blinker light circuits. They're around 8 bucks a piece. This solves the problem of extremely fast flashing.
I've just installed LED's everywhere but the front blinkers. That way there's no issue.
By the way, LEDTronics.com is the place to go for 1156 taillight/brakelight and reverse light bulbs. I got my interior stuff from Superbrightleds.com Both have superior customer service.
Lindy
I’m listening.
