Re: Billet valve covers
[Re: TRENDZ]
#2195858
11/13/16 07:05 PM
11/13/16 07:05 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
"..A little known fact about factory heads is that the valve cover bolt holes are not square to the rail. They are all tipped toward the intake side. Also the rail area where the bolts are drilled are also tipped. This means a flat surfaced valve cover will not sit evenly on a factory cast head." quoted from TRENDZ I discovered that when I put studs in the "452" heads I used on my '64 Polara and tried fitting the Mopar Performance cast valve covers on the engine in the car. I had to slot the holes to make them fit
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: AndyF]
#2248968
02/07/17 05:06 AM
02/07/17 05:06 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Andy, is that plexi glass or lexan or? that you used for the clear top. I have seen some SS semi cars with clear tops. I think Wescott used to make them for Hemis.
[Re: AndyF]
#2249042
02/07/17 12:45 PM
02/07/17 12:45 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I made my second gen valve covers with the exhaust side laid over at an angle to provide more clearance for the HP manifolds. That is purdy
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: rowin4]
#2249080
02/07/17 01:56 PM
02/07/17 01:56 PM
Posts: 31,068 Oregon
AndyF
Andy, is that plexi glass or lexan or? that you used for the clear top. I have seen some SS semi cars with clear tops. I think Wescott used to make them for Hemis. It is clear polycarb. I'm not sure if the shop buys LEXAN or some other brand.
[Re: AndyF]
#2249498
02/08/17 01:56 AM
02/08/17 01:56 AM
Posts: 5,620 long island NY
Ari440
long island NY
ANDY
can you make valve cover spacers 1/2 for B1 heads ?
1.39 9.85 - 137 mph
[Re: HDNMOPERS]
#2249508
02/08/17 02:20 AM
02/08/17 02:20 AM
AndyF
Andy do you sale these valve covers. How can I get a set. I don't have any for sale right now but I can make more. They cost $1000 per set.
[Re: LA360]
#2249509
02/08/17 02:22 AM
02/08/17 02:22 AM
AndyF
How heavy are the Big Block valve covers Andy? I haven't weighed them. They are a little heavier than a cast cover. They can be made lighter but it takes more machine time.
[Re: Ari440]
#2249903
02/08/17 08:15 PM
02/08/17 08:15 PM
AndyF
ANDY
can you make valve cover spacers 1/2 for B1 heads ? I don't have any B1 dimensions so no I can't make spacers for them. But it isn't very hard to do if you own B1 heads. Just use a set of valve covers as a template to start with. That will probably get you close enough and then go from there. Or call up Koffel and ask them for a drawing so you can get some spacers made.
[Re: LA360]
#2976688
10/21/21 01:26 AM
10/21/21 01:26 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
ANDY
can you make valve cover spacers 1/2 for B1 heads ? I can LA360, can you make a set for a small block? I have Trick Flow heads.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
