Re: Disc Brake help needed
[Re: ahy]
#2068678
05/07/16 02:11 AM
05/07/16 02:11 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Later B, E and (I think) A bodies used an 11.75" "unicast" rotor. Late B only on your list. A's and E's, never, unless someone swapped them in. C's and truck used a thicker 11.75" unicast rotor. If the rotor is 1" thick it's the late B/R body rotor. If it's 1.25" thick it's the C/truck rotor. Compare a 78 Cordoba (B body) to a 78 New Yorker (C body) rotor specs.
[Re: jimm69]
#2068798
05/07/16 12:23 PM
05/07/16 12:23 PM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
I have a 69 Roadrunner. Somewhere down the line someone did a disc brake conversion on the car. I do not know what they are. Trying to buy rotors but can not seem to find right ones. They are 11.75 in diameter. It appears all B, E, A bodies all use 11" rotors. Could be C body. Bought set for a 71 Fury but offset was wrong. Can anyone help me identify what I have so I can buy something? Isn't there a part number stamped in the inside of the rotor?
Abe Lincoln
[Re: jimm69]
#2070008
05/09/16 12:02 PM
05/09/16 12:02 PM
Supercuda
About to go away
About to go away
up yours
Calipers have more flexibility. The adapter that connects the caliper to the spindle accounts for the increased diameter of the rotor.
Basically, there are two possible caliper types you could have, one is held to the adapter via pins (called pin type), the other sets in a machined guide in the adapter (called sliders).
Once you figure out how they are mounted then you can potentially figure out the donor, I say potentially because piston diameter will also be a factor,
[Re: jimm69]
#2070345
05/09/16 09:43 PM
05/09/16 09:43 PM
Posts: 31,050 Oregon
AndyF
Thanks everyone. I found my rotors. They are from a 1978 Cordoba. Fit perfectly. I wonder if/when I need calipers if it will be the same application. Take a picture and post it on here and we'll tell you what you have. It is fairly easy to tell what the parts are from a picture.
[Re: jimm69]
#2071026
05/10/16 08:56 PM
05/10/16 08:56 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
used rotors and caliper brackets from a 75 cordoba , calipers did not fit , I like the pin type so i used 71 charger calipers 2.75 piston , i thought all b bodyies had 2.75 inch pistons
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
[Re: jimm69]
#2071029
05/10/16 09:06 PM
05/10/16 09:06 PM
Supercuda
About to go away
About to go away
up yours
I don't know about B bodies or pin type calipers. I used sliders and diameter varies depending on donor.
Example,
73 Dart 2.6" A body 78 Aspen, 2.75" F body
Both slider types.
[Re: sparcy]
#2071161
05/10/16 11:58 PM
05/10/16 11:58 PM
RapidRobert
i thought all b bodyies had 2.75 inch pistons I'm pretty sure they do (A bodies-2.60 in 73/4/5 & went to 2.75 in '76)
