Re: lifter valley plate for trick flows
[Re: AndyF]
#2067985
05/05/16 09:50 PM
05/05/16 09:50 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Interesting that Edelbrock hasn't stepped up to the plate yet to make one of these Hmmm... I wonder if anyone else has one programmed in the CNC file yet ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I wish these heads were available when I built my engine ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Jimbo]
#2068097
05/06/16 01:54 AM
05/06/16 01:54 AM
Posts: 31,076 Oregon
AndyF
The billet valley plates have a taper on the edges since they are designed to fit under an Indy head. When you use them with a standard head such as the Edelbrock or Trick Flow then you end up with a narrow gap between the knife edge and the head. You can fill in the gap with RTV but I think it will leak fairly quickly.
I can think of a couple of possible solutions but I'll have to make the parts myself to fix the issue since nobody else has solved the problem yet.
[Re: Jimbo]
#2068122
05/06/16 04:12 AM
05/06/16 04:12 AM
Posts: 4,647 aotearoa
rebel
aotearoa
i did this for my Stage 6 heads. a little bit of sealer when you screw it down & its done.
[Re: rebel]
#2068280
05/06/16 01:51 PM
05/06/16 01:51 PM
Thumperdart
State of confusion
i did this for my Stage 6 heads. a little bit of sealer when you screw it down & its done. Are you runnin a pcv valve or a vac pump...............
[Re: AndyF]
#2068292
05/06/16 02:06 PM
05/06/16 02:06 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I can think of a couple of possible solutions but I'll have to make the parts myself to fix the issue since nobody else has solved the problem yet. If you do I'd buy a few from you...maybe TF would carry them too! Might work well with their MW head when released!
Brian Hafliger
[Re: 66er]
#2068312
05/06/16 02:40 PM
05/06/16 02:40 PM
Thumperdart
State of confusion
I use an Indy style valley plate with RPM heads. I put Rite Stuff between my intake and the bevelled edge of the plate. There is a fairly large sealing surface in that area. I've been running this way for a couple years with zero leaks. Any pics............
[Re: Thumperdart]
#2068322
05/06/16 03:00 PM
05/06/16 03:00 PM
Posts: 370 Real North Cal.
66er
Real North Cal.
I don't know if you can see it but here's a picture
[Re: Jimbo]
#2068326
05/06/16 03:09 PM
05/06/16 03:09 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Are the ports raised or significantly larger that an oe pan wont work? I had some stage 6 heads that the ports were raised higher than stock stage 6s. I made a factory style, port encircling pan for that set up. not a big deal for me. Seems that if a special pan is needed it would be very easy to have made. I have access to a laser and brake. Let me know if this is something that needs to be on the market.
[Re: Brian Hafliger]
#2068362
05/06/16 04:04 PM
05/06/16 04:04 PM
AndyF
I can think of a couple of possible solutions but I'll have to make the parts myself to fix the issue since nobody else has solved the problem yet. If you do I'd buy a few from you...maybe TF would carry them too! Might work well with their MW head when released! If the guys at Trick Flow think about the problem at all they'll raise the ports on the MW version. Once the ports are raised and the intake surface extended this whole problem goes away. If they release a set of MW heads with stock port location then they just shoot themselves in the foot since single 4bbl intakes won't fit and the flow will be poor.
[Re: RT540]
#2068434
05/06/16 06:24 PM
05/06/16 06:24 PM
Thumperdart
State of confusion
My old B1BS heads had an alum. bar bolted under the edge of the intake port of the heads that was milled 45 degrees. The bara also had small threaded holes for allen screws. I still have some pics, if anyone would like to see! Sure.............
[Re: Thumperdart]
#2068458
05/06/16 07:17 PM
05/06/16 07:17 PM
rebel
aotearoa
i did this for my Stage 6 heads. a little bit of sealer when you screw it down & its done. Are you runnin a pcv valve or a vac pump............... neither, i have a catch can it vents into.
#2068511
05/06/16 10:15 PM
05/06/16 10:15 PM
dartman366
Mt. Vernon, Ohio
I can think of a couple of possible solutions but I'll have to make the parts myself to fix the issue since nobody else has solved the problem yet. If you do I'd buy a few from you...maybe TF would carry them too! Might work well with their MW head when released! Ditto that, I'm going to be needing one my self with the removeable inspection plate.
