Solid roller cam in a magnum block
#2066830
05/03/16 11:13 PM
05/03/16 11:13 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I have a customer who's looking to put a solid roller cam in a stroker small block that will be built from a magnum block. Anyone know what lifters are the best fit, and just how much grinding is required to get them to work?
Re: Solid roller cam in a magnum block
[Re: fast68plymouth]
#2066854
05/03/16 11:50 PM
05/03/16 11:50 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Check these ones out and give him a call. I just bought a set for a 360 I am building and a test fit showed them sliding right in but I have an LA block (old style). I used the comps on my last build and had to do LOTS of grinding. http://www.mrlperformance.com/
#2066877
05/04/16 12:30 AM
05/04/16 12:30 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
MRLs in my Magnum 408, drp right in.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: B1MAXX]
#2067197
05/04/16 03:15 PM
05/04/16 03:15 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
I've done a couple motors with the MRL's and they look like they should clear but it's been a while since I had a Magnum block in front of me.
They will pushrod oil with no problem so they should be a good fit for the Magnum heads. In fact on my 59 degree 70 340 block I've restricted about 95% of the oil through the block. the .815 diameter rollers with direct oiling are a nice feature plus they are strong and light. I replaced a set of Morels on my 414 with the MRL's and they were about 3 ounces PER PAIR lighter.
Here's a pic, they look like they'll have plenty of top side clearance.
#2067202
05/04/16 03:18 PM
05/04/16 03:18 PM
fast68plymouth
So. Burlington, Vt.
The block in question still has the oil feed holes for the LA style heads.
Thanks for the responses....... Sounds like the MRL's will get the job done.
#2067490
05/04/16 10:54 PM
05/04/16 10:54 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Magnum blocks from 92-95 still have the oil feed hole in the deck for LA heads, 96 to 2003 would have to be drilled.
MRL lifters will clear no problem in a magnum block I am running them in my 410 magnum stroker.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: slammedR/T]
#2067523
05/04/16 11:28 PM
05/04/16 11:28 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Magnum blocks from 92-95 still have the oil feed hole in the deck for LA heads Is this a 'for sure' cause.. that'll save me from one ginormous headache.
When it takes more than a sweet mullet to prove you rule at the trailer park..
#2067544
05/05/16 12:06 AM
05/05/16 12:06 AM
slammedR/T
My 92 date code 360 magnum block I put into my fathers 1990 ramcharger has the oil feed hole. The 95 date code magnum block I'm currently using for my 410 stroker has the oil feed hole. the stock 2000 date code magnum block I had doesn't have the feed but a machine shop should have no issue drilling the feed hole by using a head gasket as a reference.
#2067562
05/05/16 12:44 AM
05/05/16 12:44 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have only seen a few early ones with it, no ryme or reason to it, I have a 93 5.9 without it. I have a friend that has a 97 with it, that is by far the latest one I seen.
It will take an above average machine shop, it needs a real long skinney bit and it has a weird angle on two planes and the target hole in the cam bearing is not big.
