rear shocks #2065260
05/01/16 02:03 PM
05/01/16 02:03 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
I need suggestions on adjustable rear shocks for the Belvedere,need to tune for the new pro bracket radials.car weighs 3320 race weight 51%f49%r.thanks,Sam.
Re: rear shocks [Re: sam64] #2065294
05/01/16 03:00 PM
05/01/16 03:00 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
If it's a foot brake 10.80 car, the rancho 9 ways are probably good enough. My car went 10.60s easily with those on only the 255/60 radials. That was with some mystery HD springs and a trans brake.
Re: rear shocks [Re: sam64] #2065343
05/01/16 04:42 PM
05/01/16 04:42 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Best double adjustable you can afford.
The more I fool with shocks, the more important I see them being in the big picture.
Re: rear shocks [Re: CMcAllister] #2065364
05/01/16 05:07 PM
05/01/16 05:07 PM
iagree
Re: rear shocks [Re: sam64] #2065531
05/01/16 10:13 PM
05/01/16 10:13 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I like Afco double adjustable.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: rear shocks [Re: sam64] #2065593
05/01/16 11:27 PM
05/01/16 11:27 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I'm all for the DA shocks. It was night and day for my car...but not at 10.80 on a pro radial...come on.
Re: rear shocks [Re: dizuster] #2065596
05/01/16 11:32 PM
05/01/16 11:32 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Don't think it will hurt his performance, only help on poor tracks as you now can adjust both. If he decides to put a faster motor in he is already set with his shocks. Is it necessary no but niether are turbos on cars.
Re: rear shocks [Re: sam64] #2065768
05/02/16 10:36 AM
05/02/16 10:36 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
A set of double adjustable Vikings aren't all that much more than a set of Ranchos really.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: rear shocks [Re: an8sec70cuda] #2066136
05/02/16 08:42 PM
05/02/16 08:42 PM
PA
ajcasini Offline
ajcasini  Offline
PA
Have a set of Viking DA shocks on the rear of my roadrunner made a world of difference over ranchos. Went from 1.39-1.44 60' time to 1.37 all the time. 3900lb car and driver.
Also have a set on the front of the white 65. Awesome adjustability can set up to leave with the wheels 3" off the ground or 3'.
I highly recommend the product.
Re: rear shocks [Re: ajcasini] #2066150
05/02/16 09:03 PM
05/02/16 09:03 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
ok which shock,viking or stocker stars?both double adj.
Re: rear shocks [Re: sam64] #2066411
05/03/16 10:32 AM
05/03/16 10:32 AM
sam64...the Vikings are cheaper. The owner told me they only make double adjustable shocks b/c they are no more expensive to manufacture than a single adjustable. The other companies just use that as a reason to jack the prices up for the doubles.
CHIP
Re: rear shocks [Re: sam64] #2093578
06/17/16 04:43 PM
06/17/16 04:43 PM
indiana PA
moparbob498 Offline
moparbob498  Offline
indiana PA
Not to hijack this thread but, I think I have a problem too, I run afco rears (da) & well I had one 1.23 - 60' time, then 1.38 to 1.41's now I was under car re plumbing fuel system & noticed the body of my shocks have dents in them? What the hell?, appears I have so much axle wind up they hit the tubes on rear end,.. I have no snubber, no ladder bars, just super stock springs, car is back halved- thanx for any input.
mopar or no car
Re: rear shocks [Re: moparbob498] #2093596
06/17/16 05:19 PM
06/17/16 05:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How many clamps on the front segments... try doubling the clamps
but the front segment isnt strong enough to stop the axle rotation..
I assume you dont have caltracs and even then they may not be
strong enough to hold back the rotation... once you can stop
the axle rotation then you need good shocks to control the axle
wave
