M/T 28" W`S................. #2062793
04/27/16 04:57 PM
04/27/16 04:57 PM
State of confusion
Thumperdart Offline OP
State of confusion
Who`s running these and at what speed/et. I have 29.5 10x5`s on a 10" rim and can`t stand the "jacked up" stance+ they`re 94 in circ iirc and the 28w`s are 88..............thankxxx................This is on a 72 Dart and would love pics if you have em also........ thumbs
Re: M/T 28" W`S................. [Re: Thumperdart] #2062815
04/27/16 05:17 PM
04/27/16 05:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We ran STD 28x10.5's on the Valiant. It went 9.0's at 150
Re: M/T 28" W`S................. [Re: Al_Alguire] #2062827
04/27/16 05:34 PM
04/27/16 05:34 PM
State of confusion
State of confusion
Cool AL, like a dumbazz I trimmed the rear fender wells to clear the 29`s and don`t want it to look too goofy............
Re: M/T 28" W`S................. [Re: Thumperdart] #2062976
04/27/16 09:20 PM
04/27/16 09:20 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Tint the windows... DARK! laugh lol had to
Re: M/T 28" W`S................. [Re: SpareParts] #2062980
04/27/16 09:29 PM
04/27/16 09:29 PM
State of confusion
State of confusion
Oh, we have a comedian on board........... laugh2
Re: M/T 28" W`S................. [Re: Thumperdart] #2063009
04/27/16 10:08 PM
04/27/16 10:08 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
28x10.5 non w
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: M/T 28" W`S................. [Re: 1967dartgt] #2063012
04/27/16 10:10 PM
04/27/16 10:10 PM
State of confusion
State of confusion
Originally Posted By 1967dartgt
28x10.5 non w
NICE..........I just might try these and they were on a friends low 8-second Mustang who now runs the 8.5 class.........
Re: M/T 28" W`S................. [Re: Thumperdart] #2063019
04/27/16 10:17 PM
04/27/16 10:17 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
9.14@145
Re: M/T 28" W`S................. [Re: SpareParts] #2063021
04/27/16 10:18 PM
04/27/16 10:18 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
haha
Dom will you have to change rear gears when you switch to a shorter tire or do you have room for more RPM?
Re: M/T 28" W`S................. [Re: ProSport] #2063025
04/27/16 10:23 PM
04/27/16 10:23 PM
State of confusion
State of confusion
haha
My 9.79 was w/a Hoosier QTP w/91 cir. and 7200 at the stripe so w/an 88 cir. maybe the math wizes can figure that out but mostly just hate the 29.5 stance and obviously they work on bad ass cars..........
Re: M/T 28" W`S................. [Re: Thumperdart] #2063030
04/27/16 10:30 PM
04/27/16 10:30 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What's your gear ratio
Re: M/T 28" W`S................. [Re: Thumperdart] #2063058
04/27/16 11:03 PM
04/27/16 11:03 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Wow, yea you'll need to switch to a different gear for sure I would think. Over 7200 RPM is quite high although some guys run more with a big block, it would make me nervous at the stripe though.
Re: M/T 28" W`S................. [Re: Thumperdart] #2063082
04/27/16 11:37 PM
04/27/16 11:37 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Roughly 3 1/2% drop in diameter. So 7200 x 103.5 = 7452. Plus, if you plan on going a little faster, 7600-7800? Can you add a spacer block between the spring and perch to lower the back end?
[image][/image]
Re: M/T 28" W`S................. [Re: Thumperdart] #2063095
04/27/16 11:51 PM
04/27/16 11:51 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
The 275 pro tire circ is 89 and the Phoenix 28.5 x 10.5 is at 90 and are about $186 each at Jegs.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: M/T 28" W`S................. [Re: 1967dartgt] #2063097
04/27/16 11:52 PM
04/27/16 11:52 PM
State of confusion
State of confusion
4.10`s..........Already on 2" blocks.......
Re: M/T 28" W`S................. [Re: Thumperdart] #2063111
04/28/16 12:15 AM
04/28/16 12:15 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
No E.T. to report... 28 x 13.5 Hoosier QTPs. Moved the rearend back approx. 2" when installing the ladder bars rather than cut on the 1/4s for clearance.(plus i like the stock wheelwell look). Only downside to doing that is slightly less weight on the rears,
Re: M/T 28" W`S................. [Re: Thumperdart] #2063120
04/28/16 12:25 AM
04/28/16 12:25 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would run it with the 4.10s.
Re: M/T 28" W`S................. [Re: 1967dartgt] #2063122
04/28/16 12:27 AM
04/28/16 12:27 AM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
28x10.5 non w
Brad, You excel at Photoshop!
[img] [/img]
Re: M/T 28" W`S................. [Re: 1967dartgt] #2063123
04/28/16 12:29 AM
04/28/16 12:29 AM
Tucson, Arizona
Tucson, Arizona
9.14@145
Dom, It's a small block. Thumbs Up?
[img] [/img]
Re: M/T 28" W`S................. [Re: Thumperdart] #2063124
04/28/16 12:29 AM
04/28/16 12:29 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Current gear/29"tire.
135.5 mph x 4.10 gear x 336/29" tire = 6436.+ 12% vert slip, =7209rpm
Same gear/28"tire.
135.5 mph x 4.10 gear x 336/28" tire = 6666.+ 12% vert slip,=7466rpm
