Rattle Can vs Paint Out Of A Gun; What's The Difference? #2058883
04/21/16 10:54 AM
04/21/16 10:54 AM
Tennessee
WyleECoyote Offline OP
Tennessee
So my boss is restoring his 99 TAH0E (yeah, you read that right) and he is painting all of his ancillary small parts with Rust-oleum, DupliColor, or whatever shelf brand spray paint is available.
I am painstakingly going through the task of doing all of my small parts by mixing and shooting with a gun.
Am I wasting my time?
What's the difference between the two paint types and methods?
Will one last longer? Is one tougher or more durable?
Just thought I'd ask and see if anyone here has an opinion (LOL).
Thanks!
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: WyleECoyote] #2058888
04/21/16 11:03 AM
04/21/16 11:03 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Wait till your boss needs to clean or especially de-grease those spray bombed parts.
I don't spray bomb anything under my hood that is important. There are just too many things that can damage the finish or that will cause the paint to fail completely.
Spraying with 2 part paint with a gun is a pain, but is worth the effort in the long run.
Master, again and still
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: WyleECoyote] #2058893
04/21/16 11:12 AM
04/21/16 11:12 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Spray paint has zip for durability compared to a 2-part paint. If you're painting something that doesn't matter, fine. If it's something that will see wear or chemicals, it will be a problem.
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: DaytonaTurbo] #2058896
04/21/16 11:22 AM
04/21/16 11:22 AM
moparx Online content
moparx  Online Content
yet many praise stuff available in rattle cans from many restoration supply companies for many high "abuse" areas such as under hood and suspension items. are these sold only for "trailer queens" ? the adds for such products suggest not. and this does not include etching primer or two part paints available in rattle cans. so how can someone come to a correct conclusion for their needs ?
beer
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: WyleECoyote] #2058903
04/21/16 11:39 AM
04/21/16 11:39 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Spray a part with rattle and urethane with a gun. Then spray with brakleen or carb clean. You will have the answer. I have motors and suspensions running around well over 10 years, still look like new. We're talking control arms, axles, intake manifolds, etc.
Doug
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: moparx] #2058920
04/21/16 12:05 PM
04/21/16 12:05 PM
fullmetaljacket Offline
All I can say is this guys, I've worked with rattle cans since the early 70's. The products out today are superior even to those lead based rattlers of yesteryear. I myself have painted K-members, shocks, rear ends, under chassis and small parts with Epoxy based rattlers or good old Rust-oLeum and others.
Like any paint job, prep and cleanness, application and flash dry times, and a reasonable amount of light coats and sanding in between and a top clear coat makes for a beautiful product. Do they hold up to chemicals, most do if applied correctly.
Chip wise, epoxy baked products have been durable, but still may chip on an occasion. Trust me when I say that.
The secret to painting most small items with spray paint is the type of cap that is used. Some caps can spray almost as wide as some spray guns and that makes for an even steven coat.
Keep your distance and apply a few light coats in between, that will get you there. Good luck.
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: WyleECoyote] #2058930
04/21/16 12:11 PM
04/21/16 12:11 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Biggest difference between the two is the ability to catalyze the paints being sprayed through a gun. This enables the finish to produce a harder and more durable surface that will stand up to more physical abuse, chemical abuse, UV, high pressure wash, etc. Spray cans typically can't be catalyzed because the paint would set up and become unsprayable because it hardens. Although I think Eastwood does offer a catalyzing rattle can now days. But I doubt it can be used more than once.
Yes, many modern rattle can finishes are decent, but simply won't match the longevity of a two part finish. Never mind the ability of a gun to provide better coverage, better atomization, and more control over the application process.
If you want to do it once and plan on keeping the car for a long time, and don't mind the associated clean up, use 2 part paints. If you're preparing for a quick sale and don't care what it looks like when its out of sight or like to redo parts every few years, spray bomb it.
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: fullmetaljacket] #2059011
04/21/16 02:11 PM
04/21/16 02:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I think you'll be the "lone wolf" on your opinion when it comes to spray bomb vs spray gun
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: WyleECoyote] #2059029
04/21/16 02:39 PM
04/21/16 02:39 PM
Kirkland, Washington
Pacnorthcuda Offline
Catalyzed paint is molecularly different than non-catalyzed. Its molecularly 'cross-linked'. Google it. FAR superior for the reasons stated than a rattle can.
That's one of the reasons the 'Rustoleum' paint jobs are such a joke.
Even low end two part paints like Omni and Nason are far superior.
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: moparx] #2059053
04/21/16 02:59 PM
04/21/16 02:59 PM
Manitoba, Canada
Manitoba, Canada
It's called marketing. Companies are good at it. In the end, a 2-part paint will be superior in chemical resistance as well as scratch and chip resistance. They are usually more expensive and much more of a pain to do all the setup and cleanup after the fact. I use spray paint for certain things, sure, just be sure to appreciate the limitations of the product before buying it.
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: DAYCLONA] #2059056
04/21/16 03:02 PM
04/21/16 03:02 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
No he won't...
Got 20+ years on rattle-can engine, suspension components...
Cleaned and degreased many times over the years...
Holding-up fine...
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: WyleECoyote] #2059058
04/21/16 03:03 PM
04/21/16 03:03 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Eastwood I believe sells spray paints in a can that are catalyzed... which would solve the biggest issue with spray cans. For me, it depends on the part. Suspension and etc... always gets done with a gun and better quality paint. Engines, I still spray paint now and then, but only for the color, I will use something more durable underneath.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: DAYCLONA] #2059239
04/21/16 08:03 PM
04/21/16 08:03 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
High grime areas. Sprayed lower control arms & brake calipers with rustoleum red spray can, aluminum on the diff cover. Other the a few
chips on the LCA, 4 years later still looks like new. It's all in the careful preparation. Lucky? Dunno. Whatever the reason I'm satisfied.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: WyleECoyote] #2059377
04/21/16 11:49 PM
04/21/16 11:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So I sprayed some suspension pieces with epoxy primer then some Omni and one piece got some runs I couldn't live with. I waited till the paint dried then put it in my blast cabinet. That dulled the finish. I then gave it to my buddy to throw in his hot tank. Two days did nothing. I had some pieces going to a chemical stripper so I gave him that as well. Of all the pieces I gave them they mentioned this piece in particular needed extra time in the tanks.
I know for a fact that anything from a spray bomb would have come off in my blast cabinet !!
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: WyleECoyote] #2059381
04/21/16 11:54 PM
04/21/16 11:54 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
No comparison!
As has already been said, it's all about the catalyst.
Rattle cans are no match for real paint.
It's so easy to shoot paint (talking suspension and underhood stuff) that there is zero reason to spend lots of time preparing parts and then to apply 6 dollar a can paint.
unions....the folks who brought you the weekend!
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: WyleECoyote] #2059396
04/22/16 12:12 AM
04/22/16 12:12 AM
md
mopars4ever Offline
mopars4ever  Offline
md
No comparison!
iagree Took me many tries but I have come to realization that spray cans just don`t hold up. I tried many different ways.
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: WyleECoyote] #2059406
04/22/16 12:23 AM
04/22/16 12:23 AM
Martin TN
ridin98ci Offline
ridin98ci  Offline
Martin TN
the magic brand stuff from rural king and TSC is good stuff....dries rock hard AND holds up to cleaners and such....one drawback is it takes a long time to dry but its worth it
LOUD AND PROUD!!!
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: RSNOMO] #2059456
04/22/16 01:26 AM
04/22/16 01:26 AM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
I spray all my engines with Mopar engine paint. very durable stuff.
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: keith airgrabber] #2059458
04/22/16 01:28 AM
04/22/16 01:28 AM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
bow
Re: Rattle Can vs Paint Out Of A Gun; What's The Difference? [Re: WyleECoyote] #2060048
04/22/16 11:34 PM
04/22/16 11:34 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I use rustoleum, various versions, for engine block, small parts, e.g. alternator bracket, suspension etc. and it works fine and chemicals haven't seemed to be a problem.
Urethane, 1 or 2 part, has a better gloss for sure.
If I had all my small parts ready and could paint them all at once, it might make sense to mix up catalyzed paint. But to cover/protect something as you go, rattle can!
