Re: Intake questions for mild 318
[Re: SLOW67]
#2059448
04/22/16 01:15 AM
04/22/16 01:15 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Does it have 318 heads or 360 heads w the larger ports? You want an intake that matches the port size in the head. Edelbrock made a 318 sized port manifold model D4B and it works better than any other 318 intake bar none.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: 318 racer]
#2060207
04/23/16 10:27 AM
04/23/16 10:27 AM
Posts: 4,986 new jersey usa
11secdart
new jersey usa
LD4B if your can find one.
[Re: 11secdart]
#2060259
04/23/16 12:02 PM
04/23/16 12:02 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
LD4B if your can find one. The Weiand Stealth/Action Plus intakes are essentially LD4B intakes. Still available new and show up in the for sale section occasionally. Ports are horribly cast (I'd bet the LD4B was too), but on the one I gasket matched 6 out of 8 were 318 sized, the other two were very close to 340/360 sized already. Aside from that, darn good intakes, and a big step up from the performer which is essential an aluminum version of the late model factory four barrel, from what I can see.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: Michael Ecks]
#2060350
04/23/16 04:05 PM
04/23/16 04:05 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
LD4B if your can find one. The Weiand Stealth/Action Plus intakes are essentially LD4B intakes. Still available new and show up in the for sale section occasionally. Ports are horribly cast (I'd bet the LD4B was too), but on the one I gasket matched 6 out of 8 were 318 sized, the other two were very close to 340/360 sized already. Aside from that, darn good intakes, and a big step up from the performer which is essential an aluminum version of the late model factory four barrel, from what I can see. I have a used 2176 performer on my daily driver 318 and what you say is true, but the manifold will also accept the A/C pump and I don't see others that will do that. I have not seen all SB manifolds so there maybe one in aluminum that does.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
