Re: 8 3/4 third member
[Re: moon]
#2057222
04/18/16 10:51 PM
04/18/16 10:51 PM
Posts: 22,696 Bitopia
jcc
Bitopia
The 742 was OEM I believe, so originality should not be an issue.
[Re: moon]
#2057419
04/19/16 03:45 AM
04/19/16 03:45 AM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
As stated, the thrust block in the differential is different, the '62 open differential axles are longer than the '64 and later. To use the 489 in the '62 you'll have to remove 1/8" from the splined end of each axle shaft.
