8 3/4 third member #2057152
04/18/16 09:06 PM
04/18/16 09:06 PM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
I have a 62 Dodge Polara 500 with tapered axles and 741 case and the third member is making noise. I have a 489 third member from a 69 Fury...will the 489 interchange with the 741 using my tapered or are the splines different?
Re: 8 3/4 third member [Re: moon] #2057206
04/18/16 10:33 PM
04/18/16 10:33 PM
blewbyu Offline
blewbyu  Offline
The axles splines should be the same and it should interchange
Re: 8 3/4 third member [Re: blewbyu] #2057216
04/18/16 10:42 PM
04/18/16 10:42 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Just check the yoke width and make sure they're the same... twocents
...FAFO...
Re: 8 3/4 third member [Re: moon] #2057222
04/18/16 10:51 PM
04/18/16 10:51 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The 742 was OEM I believe, so originality should not be an issue.
Re: 8 3/4 third member [Re: moon] #2057261
04/18/16 11:43 PM
04/18/16 11:43 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Open or sure grip in the 62 Polara? There is a difference in the thrust block.
Re: 8 3/4 third member [Re: NANKET] #2057310
04/19/16 12:25 AM
04/19/16 12:25 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
Open
Re: 8 3/4 third member [Re: moon] #2057419
04/19/16 03:45 AM
04/19/16 03:45 AM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
As stated, the thrust block in the differential is different, the '62 open differential axles are longer than the '64 and later. To use the 489 in the '62 you'll have to remove 1/8" from the splined end of each axle shaft.
