Making blower manifold looking for guru #205620
01/27/09 08:22 AM
01/27/09 08:22 AM
Lost
gaza Offline OP
gaza  Offline OP
Lost
Hi all
I'm about to start building a blower manifold for a 14/71 mooneyham on to a aluminum A engine.
I have been reading a bit about people using a lot of blower setback, has anyone got any more info on this or any other info I should know.
Re: Making blower manifold looking for guru [Re: gaza] #205621
01/27/09 09:34 AM
01/27/09 09:34 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Good luck. I hope you don't give new meaning to the term, "pop can".
Re: Making blower manifold looking for guru [Re: gaza] #205622
01/27/09 11:02 AM
01/27/09 11:02 AM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
If your interested you can buy one from Max-Wedge
Performance in Australia. They cast them for the A engine. Here is the info I have.
Bill Laney
williaml@hotkey.net.au
Re: Making blower manifold looking for guru [Re: gaza] #205623
01/27/09 04:43 PM
01/27/09 04:43 PM
Be careful on the set back unless your going to use a front drive and front mounted distributor or coil per cylinder ignition because of the rear of the blower hitting the distributor
Re: Making blower manifold looking for guru [Re: Cab_Burge] #205624
01/27/09 05:26 PM
01/27/09 05:26 PM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
A 14-71 will hit the distributor without any setback.
Re: Making blower manifold looking for guru [Re: hemi471] #205625
01/27/09 05:35 PM
01/27/09 05:35 PM
Lost
gaza Offline OP
gaza  Offline OP
Lost
Bill Laney
I should have said this is a W9 headed engine which bill doesn't make a manifold for, they are nice units though.
Cab_Burge
I am using a front mount MSD which has an offset drive
Re: Making blower manifold looking for guru [Re: gaza] #205626
01/27/09 08:30 PM
01/27/09 08:30 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
You could start with a TR, and go from there...
Re: Making blower manifold looking for guru [Re: gaza] #205627
01/27/09 08:41 PM
01/27/09 08:41 PM
What kind of blower are you using? Inlets ,outlet,highhelix? The set back deal is mainly for the front discharge blowers. They have an outlet that is a small delta (pie shape).This pushs the air all to the front of the case and it comes out at near a 45degree angle. So it pushes more air to the front clyinders and less to the back if monted in stock location.The newest set back manifolds set the blower way back on the motor. Keep in mind that the snouts for a full set back are very expensive( $2500 and up for just the snout).There are other options.Depending on what you plan on running a full set back isn't worth the money in most guys opion.Hope this helps
Re: Making blower manifold looking for guru #205628
01/27/09 09:13 PM
01/27/09 09:13 PM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
$2500 just for a snout!!?? And I cried when I broke the basic BDS snout and had to get the billit super snout
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Making blower manifold looking for guru [Re: gaza] #205629
01/27/09 09:21 PM
01/27/09 09:21 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
the Koffels place Lake erie monster uses a 4bbl intake with a 14. a lot of bracing going to the plate holding the blower and a lot of aligning placing the mounting studs.it works great though.
Re: Making blower manifold looking for guru #205630
01/27/09 11:28 PM
01/27/09 11:28 PM
Lost
gaza Offline OP
gaza  Offline OP
Lost
It's large inlet, standard outlet, not high helix(didn't fit the current budget).
So if I follow correctly it won't really make any difference unless it's high helix blower.
I'll just center it on the runners then if theirs nothing in it.
Thanks for that
Re: Making blower manifold looking for guru [Re: gaza] #205631
01/28/09 08:11 PM
01/28/09 08:11 PM
There is power to be found by seting the blower back. It is more to even out the air and fuel.But in most cases if money is not a problem then go for it.But if your like the rest of use playing with something you shouldn't be (Don't feel bad I can't help my self either).The other option is not setting the blower completely back.Mine that we ran last year is back 3 5/8".We got a 8" snout from jr at rbs super chargers for I think aroud $500-600.By the way a 8" snout is really 8 5/8" long.If you are going to move things around make shure of you acuall snout length.To give you an exsample our hat jets in the front are 68's Still to lean and our backs are 32's and there still cold. If we could se the blower back more it would help even that out.When we moved it from stock spot to 3 5/8 back we picked up heat on 2 more cylinders with no other changes.With your blower big openings (like what we use to run) I don't think you will see that much of a problem.Just depends on what you plan on doing later on down the road and really what can you spend.If I can help just let me know.
Re: Making blower manifold looking for guru [Re: blownzoom440] #205632
01/28/09 08:12 PM
01/28/09 08:12 PM
Do you have any spec on the motor?
Re: Making blower manifold looking for guru #205633
01/29/09 01:08 AM
01/29/09 01:08 AM
Lost
gaza Offline OP
gaza  Offline OP
Lost
W9 Heads
INTAKE: 1-82 2-159
3-234 4-292 5-307 6-370 7-384 8-393 EXHUST: 1-62 2-116 3-180
4-223 5-244 6-264 7-271 8-278
EXHUST WITH 2 INCH PIPE 1-62 2-116
3-188 4-232 5-264 6-288 7-295 8-302
P5249813 tall deck alloy block
We haven't decided on the rotating assembly yet but most likely a 4" crank, we are tailking about changing the snout to hemi for easier access to pulleys.Should be in the mid to high 400 cube area depending on how much we decide to take out of the bore.
Re: Making blower manifold looking for guru [Re: gaza] #205634
01/29/09 01:11 AM
01/29/09 01:11 AM
Lost
gaza Offline OP
gaza  Offline OP
Lost
another pic of the hardtop
Re: Making blower manifold looking for guru [Re: blownzoom440] #205635
01/29/09 01:16 AM
01/29/09 01:16 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
What was the reason for doing that? Is it a class thing?
Re: Making blower manifold looking for guru [Re: dthemi] #205636
01/29/09 05:22 AM
01/29/09 05:22 AM
ELYRIA,OH
ELYRIA,OH
no, thay wanted to se how it would work.it does pritty good too!
Re: Making blower manifold looking for guru [Re: gaza] #205637
01/29/09 08:00 AM
01/29/09 08:00 AM
Tomorrow.
Damned67 Offline
Damned67  Offline
Tomorrow.
Love those hardtops....
A good mate of mine helped a lot starting up the hardtop registry. Not sure if it's still around or not though.
I'm in Brisbane myself, so would love to see your ride once it's finished!
Sorry, I can't help with your question, it's way out of my league..
Re: Making blower manifold looking for guru [Re: blownzoom440] #205638
01/29/09 08:02 AM
01/29/09 08:02 AM
Brisbane Australia
572B1 Online content
572B1  Online Content
Brisbane Australia
Hi Gary,A good friend of mine had one custom made for a big block chev in a commodore.He bought a used 14/71 off victor bray and had Weldwell engineering in brisbane make a custom blower manifold. The car ran 7.20s and the manifold was a work of art.Give weldwell a call.
Ps hows my fibreglass bonnet coming along.
Re: Making blower manifold looking for guru [Re: 572B1] #205639
01/29/09 08:24 AM
01/29/09 08:24 AM
Lost
gaza Offline OP
gaza  Offline OP
Lost
Thanks for the info. Making the manifold is not really a problem, I just saw a bit of info on the web about setback and was wondering if there was enough of a performance gain to make it worthwhile playing around with it.
I'll call you about that
