Re: Deep transmission pan
[Re: LTLBEE]
#2056303
04/17/16 06:52 PM
04/17/16 06:52 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Here ya go. Almost not worth a JY visit...........
http://www.ebay.com/itm/Transmission-Oil-Pan-46RH-46RE-47RE-47RH-48RE-727-New-a727-a518-a618-518-618-/290545854496?hash=item43a5e1e820:g:wFoAAMXQDK1RwmE7&vxp=mtr
[Re: LTLBEE]
#2056436
04/17/16 11:15 PM
04/17/16 11:15 PM
Posts: 9,835 MI, usa
dvw
MI, usa
John, If I got the deep pan from the junkyard Are the filter extensions on the transmissions already and I could take it off of that with the pan No , the 518 uses a different style filter. I made my own extension as the 518 pan is deeper than most deep pans. If I remember it was about 1.75" thick. Doug
[Re: BDW]
#2056437
04/17/16 11:17 PM
04/17/16 11:17 PM
RapidRobert
John what is the ideal filter to pan clearance?
[Re: Azzkikrcuda]
#2057420
04/19/16 03:48 AM
04/19/16 03:48 AM
Posts: 25,790 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The spacer places the filter down near the bottom of the pan where it belongs.
[Re: Torq37]
#2057767
04/19/16 06:00 PM
04/19/16 06:00 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Do you really need a spacer since you are filling the trans to the same Level as before I’ve wondered about this as well. Other than promoting better circulation at the bottom of the pan for cooling I don’t see what difference it makes assuming you keep the fluid level between the marks. Would you put a deep sump pan on an engine and have the stock pick-up 2" off the bottom of the pan ?
[Re: 62maxwgn]
#2057882
04/19/16 08:52 PM
04/19/16 08:52 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Obviously there will be more fluid in the pan and therefore the fluid will be cooler just because of the volume of it...so use the extension that matches the pan so it does not run low and suck air.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
