Deep transmission pan #2056298
04/17/16 06:47 PM
04/17/16 06:47 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
I want to put a deep transmission pan on my 727 transmission . What newer transmission pan is the same as the 727, Is it the 518. Im going to look for one in the junkyard does anyone know what vehicle I should try looking for one on.
Re: Deep transmission pan [Re: LTLBEE] #2056302
04/17/16 06:51 PM
04/17/16 06:51 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
I know this doesn't answer your question, but I ended up buying one on Amazon for a 46RE transmission.
http://www.amazon.com/Dorman-265-827-Transmission-Pan/dp/B009T4M1OG
You may not save much money over that one by pulling one from a junk yard.
Re: Deep transmission pan [Re: LTLBEE] #2056303
04/17/16 06:52 PM
04/17/16 06:52 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Here ya go. Almost not worth a JY visit...........
http://www.ebay.com/itm/Transmission-Oil-Pan-46RH-46RE-47RE-47RH-48RE-727-New-a727-a518-a618-518-618-/290545854496?hash=item43a5e1e820:g:wFoAAMXQDK1RwmE7&vxp=mtr
Re: Deep transmission pan [Re: LTLBEE] #2056314
04/17/16 07:11 PM
04/17/16 07:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Deep transmission pan [Re: mopowers] #2056316
04/17/16 07:13 PM
04/17/16 07:13 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
Thanks. Any specific type of vehicle I should try looking for like a Durango or Dakota
Re: Deep transmission pan [Re: LTLBEE] #2056317
04/17/16 07:14 PM
04/17/16 07:14 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Check your local dodge dealer for a 1" filter extension. I picked one up for $22 from mine.
Re: Deep transmission pan [Re: John_Kunkel] #2056323
04/17/16 07:22 PM
04/17/16 07:22 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
John, If I got the deep pan from the junkyard Are the filter extensions on the transmissions already and I could take it off of that with the pan
Re: Deep transmission pan [Re: mopowers] #2056324
04/17/16 07:23 PM
04/17/16 07:23 PM
BDW Online content
BDW  Online Content
Got a PN?
I used same pan on my 518, it needs a spacer but thought it should be ~0.7"
Re: Deep transmission pan [Re: LTLBEE] #2056436
04/17/16 11:15 PM
04/17/16 11:15 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No , the 518 uses a different style filter. I made my own extension as the 518 pan is deeper than most deep pans. If I remember it was about 1.75" thick.
Doug
Re: Deep transmission pan [Re: BDW] #2056437
04/17/16 11:17 PM
04/17/16 11:17 PM
John what is the ideal filter to pan clearance?
Re: Deep transmission pan [Re: RapidRobert] #2057129
04/18/16 08:40 PM
04/18/16 08:40 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
Thanks for the help. I got the pan from the junkyard today for $5. Now I just have to get the spacer.
Re: Deep transmission pan [Re: LTLBEE] #2057178
04/18/16 09:59 PM
04/18/16 09:59 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Do you really need a spacer since you are filling the trans to the same Level as before work
The only Carbs I care about are under the hood!
Re: Deep transmission pan [Re: Azzkikrcuda] #2057420
04/19/16 03:48 AM
04/19/16 03:48 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The spacer places the filter down near the bottom of the pan where it belongs.
Re: Deep transmission pan [Re: Azzkikrcuda] #2057557
04/19/16 01:18 PM
04/19/16 01:18 PM
Torq37 Offline
Torq37  Offline
I’ve wondered about this as well. Other than promoting better circulation at the bottom of the pan for cooling I don’t see what difference it makes assuming you keep the fluid level between the marks.
Re: Deep transmission pan [Re: Torq37] #2057767
04/19/16 06:00 PM
04/19/16 06:00 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Would you put a deep sump pan on an engine and have the stock pick-up 2" off the bottom of the pan ?
Re: Deep transmission pan [Re: 62maxwgn] #2057882
04/19/16 08:52 PM
04/19/16 08:52 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Obviously there will be more fluid in the pan and therefore the fluid will be cooler just because of the volume of it...so use the extension that matches the pan so it does not run low and suck air.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Deep transmission pan [Re: LTLBEE] #2057885
04/19/16 08:55 PM
04/19/16 08:55 PM
BDW Online content
BDW  Online Content
Engine comparison is not valid. I'm sure it's slightly cooler fluid at the bottom, but I don't think it's a big deal. Windage isn't a problem, there's no where for the fluid to "slosh" around like an engine.
If the fluid level is full, I think it's good to go. I have deep pan on my 518 with no extension.
Only put 3-4K on it so far, we'll see how it goes.
