Re: Choosing Bearings
[Re: jeebis44]
#2053691
04/13/16 03:19 PM
04/13/16 03:19 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
King is top-of-the-line IMO. But overkill for your use. In terms or what you plan any stock type bearing is fine. A name brand tri-metal will give long life and performance and not break the bank. I don't use full groove mains. If it's racey I'll go 3/4 groove but most builds get std grooves. The longer the groove, the longer (in terms of crankshaft degrees) the oil bearing is exposed to pressurized oil. Full grooves reduce the load carrying ability of the main bearing but when coupled with a higher volume oil pump it lets the rods take more abuse.
[Re: jeebis44]
#2056066
04/17/16 12:36 PM
04/17/16 12:36 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Reasonable power in a stockish build just us the stock type "P" bearings. The embedment characteristic is desirable, nothing to be gained by a "H" type for what you're doing
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
