Choosing Bearings #2053632
04/13/16 01:41 PM
04/13/16 01:41 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Looking for bearings for my '82 Gran Fury LA318 - mild performance engine, daily driver driven severely.
How do I choose the right main/rod bearings? I see so many options: Bi-metal, Tri-metal, 1/2, 3/4, full groove
Which type do I choose? I intend to drive this car hard on the street for many years before I have to rebuild it...
Re: Choosing Bearings [Re: jeebis44] #2053674
04/13/16 02:52 PM
04/13/16 02:52 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
King SI bearings any good? Looking at the bimetal 1/2 groove version
Re: Choosing Bearings [Re: jeebis44] #2053687
04/13/16 03:17 PM
04/13/16 03:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Look at clevite they are good. Seems to me you are going overkill for a 318 that will be a daily driver. You aren't going to be able to drive it hard enough on the street to worry about using high dollar race parts. Not trying to burst your bubble but with the weight of the car and the engine and drivetrain combo you are contemplating I believe you are going to be very disapointed in the performance. shruggy
Re: Choosing Bearings [Re: jeebis44] #2053691
04/13/16 03:19 PM
04/13/16 03:19 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
King is top-of-the-line IMO. But overkill for your use.
In terms or what you plan any stock type bearing is fine. A name brand tri-metal will give long life and performance and not break the bank.
I don't use full groove mains. If it's racey I'll go 3/4 groove but most builds get std grooves. The longer the groove, the longer (in terms of crankshaft degrees) the oil bearing is exposed to pressurized oil. Full grooves reduce the load carrying ability of the main bearing but when coupled with a higher volume oil pump it lets the rods take more abuse.
Re: Choosing Bearings [Re: jeebis44] #2056066
04/17/16 12:36 PM
04/17/16 12:36 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Reasonable power in a stockish build just us the stock type "P" bearings. The embedment characteristic is desirable, nothing to be gained by a "H" type for what you're doing
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
