Page 4 of 4 1 2 3 4
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2051392
04/10/16 10:38 PM
04/10/16 10:38 PM
Wild West
M_D Offline
M_D  Offline
Wild West
Originally Posted By Moparguy383
Yes I have tried all of the caps. Yes I am putting them back in the right spot, not only are the numbered but I also took pictures of it when it came back from the machine shop.
To get the measurement down inside the block, I used all thread and some long nuts. All thread about an inch shorter than I needed. Backed the nuts off the all thread until it was tight (not crazy tight) going in and out of the block. Locked the nuts with secondary nuts. Took it out and measured it. I know it might be off a little, but certainly not .020 of an inch
A micrometer works on the same principle, but there is a difference in precision.
I don't know if you have said how you tried to install the caps, pulling them on with bolts or if you were just using hand pressure which will not work unless they are too loose.
As others have said, if there was actually a .02" thousandths difference there is no way they would go on the block without a tremendous amount of force, that's a huge press fit. If one were to somehow use enough force to get them on, substantial damage would be inevitable, might even split the main bores.
If the caps were actually installed at the machine shop there will be marks on the cap register surfaces and if they were honed on your block there will be honing marks that match between the caps and the block. Each one will have a slightly unique pattern and with a good eye and careful inspection many people could easily tell if the caps matched the block and even know which cap goes where, even without stamped numbers.
Assuming the caps were properly installed before, it's just a matter of using enough force to pull them on with the bolts or studs. Alternate back and forth to keep them reasonably even.
It is possible to ding up the registering surfaces with improper installation techniques, which could increase the pressure required substantially. So it's not a bad idea to closely inspect the mating surfaces for any damage and dress the high spots if needed.
Re: Billet Main Cap Question, Part 2 [Re: pittsburghracer] #2051527
04/11/16 12:45 AM
04/11/16 12:45 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By pittsburghracer
Originally Posted By 383man
I use my telescoping gauges alot for a measurement like that and then just mike the telescoping gauge. Ron
An honestly that not good enough for what he is doing. I use inside Mics and they are always calibrated with my outside Mics that are calibrated with my standards
It depends on where I use them as you have to have a feel for them. I dont use them all the time but at times they work good and give very accurate readings. I know without a reading right on them like an inside mike has can cause some not to trust them. And the tool you measure them with has to be accurate. I have used them alot with good readings. But I dont use them all the time as at times I agree with you and prefer a tool with a gauge right on it. Ron
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2051863
04/11/16 02:30 PM
04/11/16 02:30 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Everyone look at the picture in the first post. The edge of the cap looks to have a bulge in it, not the flat surface it should have. If that's real, the block and caps need to be taken to a different shop........
Re: Billet Main Cap Question, Part 2 [Re: deaks] #2051870
04/11/16 02:43 PM
04/11/16 02:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By deaks
Watch what this guy does at 4 mins into this clip.
https://www.youtube.com/watch?v=e3r3wRBoXkk
he did all that stuff BEFORE he linehoned it , not after ...
But then again it's a SBC rolleyes
Re: Billet Main Cap Question, Part 2 [Re: varunner] #2051979
04/11/16 05:23 PM
04/11/16 05:23 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Really?
That's the register on the cap.
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2052115
04/11/16 08:20 PM
04/11/16 08:20 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Were they machined with bolts or studs installed?
If they had bolts and changing to studs, the thicker stud might cause a slight alignment issue and the holes in the caps may need to be enlarged to compensate?
Re: Billet Main Cap Question, Part 2 [Re: 451Mopar] #2052130
04/11/16 08:38 PM
04/11/16 08:38 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Great post
Re: Billet Main Cap Question, Part 2 [Re: FastmOp] #2052441
04/12/16 12:47 AM
04/12/16 12:47 AM
Cumberland, MD
Moparguy383 Offline OP
Cumberland, MD
They were machined with the studs installed.
I am going to borrow the proper measuring tools and recheck my figures before I call the machine shop or 440source.
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2052609
04/12/16 09:31 AM
04/12/16 09:31 AM
moparx Offline
moparx  Offline
yet your pic shows you trying to install the caps without the studs installed ? that's why i recommended making alignment dowels to help keep the cap square. i didn't know you are using studs. are the cap holes reamed to fit the studs being used ? too many things going on here including not being able to accurately measure anything to make suggestions to solve the problem. not trying to offend, but to understand better.
beer
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2052712
04/12/16 12:47 PM
04/12/16 12:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Call the machine shop!
'source isn't going to be able to tell you anything that is going to help ...
They already told you to hit them on a belt sander
Page 4 of 4 1 2 3 4
