Air filter question??? #2051155
04/10/16 05:10 PM
04/10/16 05:10 PM
Port Huron, Michigan
MI_Custumz Offline OP
Have a 2008 T&C with the V6 and a 2008 Avenger with a 4 cylinder. Fram says CA9054 fits both. Was thinking of going to Wix for air filters at rock auto. I looked up the parts and wix p/n 42389 for the van and 49926 for the car. Why would the wix have two separate p/n's for wix and one for fram? I looked at the dimensions and the wix for the car is not as tall as the one for the van. I had a hard time closing the one air box, but can't remember which one. Maybe I have found the reason, Fram is taller than the wix for the car. Why the one filter for both from Fram?
Re: Air filter question??? [Re: MI_Custumz] #2051167
04/10/16 05:26 PM
04/10/16 05:26 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
Fram doesn't care enough to make their filters for the application. Close enough is good for Fram. Extra tall filter may be OK until your air box is all stripped out, or cracked from forcing the wrong filter in. Use the Wix.
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: Air filter question??? [Re: MI_Custumz] #2051168
04/10/16 05:26 PM
04/10/16 05:26 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
The 49926 has complaints on Amazon for being wrong. The 42389 has all positive reviews. Based on that I'd say in typical internet fashion once one gets it wrong it snowballs. 42389 seems like your filter. But I'd do a bit of leg work yourself before pulling the buy trigger
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
