70 GTX hood turn indicator parts #2051007
04/10/16 01:31 PM
04/10/16 01:31 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Does anyone have a part # for the wire with the brass socket or know where I can purchase one??
Driving modern convenience in classic beauty
Re: 70 GTX hood turn indicator parts [Re: Darius] #2051104
04/10/16 03:42 PM
04/10/16 03:42 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Re: 70 GTX hood turn indicator parts [Re: Darius] #2051123
04/10/16 04:09 PM
04/10/16 04:09 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
Thank you!
Re: 70 GTX hood turn indicator parts [Re: Darius] #2051182
04/10/16 05:54 PM
04/10/16 05:54 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
That's where I got mine. Nice quality, but brace yourself for sticker shock
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 70 GTX hood turn indicator parts [Re: Darius] #2052906
04/12/16 05:01 PM
04/12/16 05:01 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I managed to repair the one with the broken wire.
Re: 70 GTX hood turn indicator parts [Re: Darius] #2053686
04/13/16 03:15 PM
04/13/16 03:15 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
Does anyone know where to wire these into? seems there would be a small harness to come off those lights (I bought them from kruis'in, years ago) could locate a wire diagram for them or how they were routed?
Re: 70 GTX hood turn indicator parts [Re: Darius] #2053780
04/13/16 06:12 PM
04/13/16 06:12 PM
northwest USA
N
NANKET Online work
NANKET  Online Work
N
northwest USA
There is a plug on the front light harness near the master cyl. They have flat spade terminals. There is an adapter harness that plugs into that plug and goes toward center of car with the round plugs that go the the bulb wires.
Re: 70 GTX hood turn indicator parts [Re: Darius] #2053813
04/13/16 07:24 PM
04/13/16 07:24 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I rewired my entire car from scratch when I swapped in the 5.7 so mine is nothing like what stock was.
Re: 70 GTX hood turn indicator parts [Re: meepmeep70] #2054338
04/14/16 04:21 PM
04/14/16 04:21 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
No biggee..
EZ to tap into the turn signal leads (bulkhead connector) that drive the left & right turn lites..
On my 70 RR, I pulled the bulkhead connector and popped out the respective tab terminals. Made new leads that had an additional wire with a female bullet connector in parallel. Plugged the bulkhead connector back in and plugged the male bullet connectors from the hood lites. If U need to know the actual terminal and wire color, post back and I will dig it out for U...
Just my $0.02... wink
Re: 70 GTX hood turn indicator parts [Re: Sinitro] #2054964
04/15/16 02:45 PM
04/15/16 02:45 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
No biggee..
Thank you Sinatro!, if you don't mind digging it out that would be great please, and too much if I asked you to post a pic of there harness run. Thank you, I have always wanted these to work ecspecially since I have the air grabber hood.
Re: 70 GTX hood turn indicator parts [Re: meepmeep70] #2056359
04/17/16 08:29 PM
04/17/16 08:29 PM
So Cal
So Cal
No biggee..
Thank you Sintro!, if you don't mind digging it out that would be great please, and too much if I asked you to post a pic of there harness run. Thank you, I have always wanted these to work ecspecially since I have the air grabber hood.
OK..
Looking at the (3) bulkhead connectors. Coming out of the middle 1 , U will find all of the front lighting wires. Look for the Black wire with a thin Tan trace this is the Right Turn signal hot. The Left Turn signal hot is the Black wire with a thin Green trace. To double check U can use a small test lamp or multimeter to verify, hit the turn signal switch and look for the switching ON/OFF 12V.
Next pull back the bulkhead connector and using a small pointed awl tool U can slide out the terminal from the bulkhead making it easier to solder the 2nd wire to it.
I hope that helps..
Re: 70 GTX hood turn indicator parts [Re: Darius] #2056477
04/17/16 11:51 PM
04/17/16 11:51 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
Greatly thank you
