70 GTX hood turn indicator parts
#2051007
04/10/16 01:31 PM
04/10/16 01:31 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Does anyone have a part # for the wire with the brass socket or know where I can purchase one??
Driving modern convenience in classic beauty
Re: 70 GTX hood turn indicator parts
[Re: Darius]
#2051104
04/10/16 03:42 PM
04/10/16 03:42 PM
Posts: 1,978 USA
Suregrip391
USA
[Re: Darius]
#2051182
04/10/16 05:54 PM
04/10/16 05:54 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
That's where I got mine. Nice quality, but brace yourself for sticker shock
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: Darius]
#2052906
04/12/16 05:01 PM
04/12/16 05:01 PM
Darius
Sacramento, Ca
I managed to repair the one with the broken wire.
[Re: Darius]
#2053813
04/13/16 07:24 PM
04/13/16 07:24 PM
Darius
Sacramento, Ca
I rewired my entire car from scratch when I swapped in the 5.7 so mine is nothing like what stock was.
[Re: meepmeep70]
#2054338
04/14/16 04:21 PM
04/14/16 04:21 PM
Posts: 5,444 So Cal
Sinitro
So Cal
Does anyone know where to wire these into? seems there would be a small harness to come off those lights (I bought them from kruis'in, years ago) could locate a wire diagram for them or how they were routed? No biggee.. EZ to tap into the turn signal leads (bulkhead connector) that drive the left & right turn lites.. On my 70 RR, I pulled the bulkhead connector and popped out the respective tab terminals. Made new leads that had an additional wire with a female bullet connector in parallel. Plugged the bulkhead connector back in and plugged the male bullet connectors from the hood lites. If U need to know the actual terminal and wire color, post back and I will dig it out for U... Just my $0.02...
[Re: Sinitro]
#2054964
04/15/16 02:45 PM
04/15/16 02:45 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
Does anyone know where to wire these into? seems there would be a small harness to come off those lights (I bought them from kruis'in, years ago) could locate a wire diagram for them or how they were routed? No biggee.. EZ to tap into the turn signal leads (bulkhead connector) that drive the left & right turn lites.. On my 70 RR, I pulled the bulkhead connector and popped out the respective tab terminals. Made new leads that had an additional wire with a female bullet connector in parallel. Plugged the bulkhead connector back in and plugged the male bullet connectors from the hood lites. If U need to know the actual terminal and wire color, post back and I will dig it out for U... Just my $0.02... Thank you Sinatro!, if you don't mind digging it out that would be great please, and too much if I asked you to post a pic of there harness run. Thank you, I have always wanted these to work ecspecially since I have the air grabber hood.
[Re: meepmeep70]
#2056359
04/17/16 08:29 PM
04/17/16 08:29 PM
Posts: 5,444 So Cal
Sinitro
So Cal
Does anyone know where to wire these into? seems there would be a small harness to come off those lights (I bought them from kruis'in, years ago) could locate a wire diagram for them or how they were routed? No biggee.. EZ to tap into the turn signal leads (bulkhead connector) that drive the left & right turn lites.. On my 70 RR, I pulled the bulkhead connector and popped out the respective tab terminals. Made new leads that had an additional wire with a female bullet connector in parallel. Plugged the bulkhead connector back in and plugged the male bullet connectors from the hood lites. If U need to know the actual terminal and wire color, post back and I will dig it out for U... Just my $0.02... Thank you Sintro!, if you don't mind digging it out that would be great please, and too much if I asked you to post a pic of there harness run. Thank you, I have always wanted these to work ecspecially since I have the air grabber hood. OK.. Looking at the (3) bulkhead connectors. Coming out of the middle 1 , U will find all of the front lighting wires. Look for the Black wire with a thin Tan trace this is the Right Turn signal hot. The Left Turn signal hot is the Black wire with a thin Green trace. To double check U can use a small test lamp or multimeter to verify, hit the turn signal switch and look for the switching ON/OFF 12V. Next pull back the bulkhead connector and using a small pointed awl tool U can slide out the terminal from the bulkhead making it easier to solder the 2nd wire to it. I hope that helps.. Just my $0.02...
